ZM-1.20.0 Fedoa Core 3 RPM
Remote camera?
I installed the latest zm rpm on a system with FC3, SeLinux disabled and a DLink DCS-900 camera.
I can see images from the camera with FireFox at 192.168.0.20/image.jpg. When I put this in zm and set the other parameters accordingly, all I get is a broken link icon when I try to view the monitor.
Any ideas?
Thanks,
Doc
Any ideas?
Thanks,
Doc
Still no images, but I noticed something strange.
Earlier, if I clicked on the "Options" link, I would get a page with several tabs across the top. The only tab that seemed to do anything was "Users" which printed a list of the users. Now, there are many settings displayed for each of the tabs. And the user name(s) are liniks which bring up settings for that user. It didn't do this last night.
Similarly if I clicked the name of my "Monitor" to look at images/streams, there was NOT a link near the top that toggled between "Stills" and "Stream". Now, this link suddenly started appearing.
Seems like the code is crashing and only displaying part of the pages. But each time I run it, it seems like new settings/links appear...Strange...
- zoneminder
- Site Admin
- Contact:
Thanks, it seems to be running great. Even got some motion detected/recorded last night. This is a nice package. I might even have to make a donation
BTW, for the record, 500 MHz Athlon, remote cam, fc3. 384 MB ram would NOT even run the cam at 320x240 with minimum buffering. But zm does run with 448 MB (256+128+64). Perhaps a list of minimum configurations in the FAQ might be useful. It might have saved me a couple days anyway.
- zoneminder
- Site Admin
- Contact:
ZM should run perfectly fine in 384Mb of memory so long as you don't have masses of cameras, massive images or huge buffers, none of which seem to apply to you. What wasn't working before? Were you getting shared memory errors? These are usually just because the configured limit is too small rather than the amount of real memory.
Phil
Phil
I was getting shared memory errors (shmget) until I changed the buffering to very low values (can't say without looking) and configuration (was at something like 22 megs per application?). Then the shmget errors ceased but zmc still crashed every time it was started (exit code 21?). No stills, no video. But when I added an old stick of 64 MB to bring it up to 448 MB, it all suddenly started working. I haven't tried increasing the buffers yet.
I tried 320x240x24(?) bit color and it wouldn't run either until I added the memory. I'm now using 640x480x24.
- zoneminder
- Site Admin
- Contact:
