Hi all
I post this as an update and final fix (at least for me) on this problem. Sorry for the time it took, but I had to be sure it worked.
Phil released a zmaudit patch for my version 1.19.5 and I believe has included this fix on all subsecuent releases. Zmaudit is the program responsible for physically deleting events from the hard drive. The patch Phil made basically tells zmaudit to NOT delete any event younger than a certain amount of seconds.
Phil set this default time frame to 300 seconds in zmaudit.pl on the following line:
use constant MIN_AGE => 300; # Minimum age when we will delete anything
As I originally stated, my setup is running nineteen Axis cameras capturing one jpg every ten seconds for 10 minute lapses.
Somewhere along the way, the MIN_AGE of 300 seconds did render a positive result upon most events not being dropped off but still some were being deleted. This happend too, added to the fact that I presume zmaudit does not run every five minutes on the hour (as events do starting and ending every 10 minutes on the hour) which led me to believe that zmaudit is triggered every 300 seconds depending on the first time it was initiated (after a restart of the system or restart from the console).
The final fix I came upon was setting MIN_AGE to 900 seconds. I figured that this was enough time for the time lapse events being created every 600 seconds to not get deleted by the "nervous" zmaudit, and it did, events do not disappear anyomore!
Finally on another
post I read that lazyleopard (I guess using modect) on its cameras found that zmaudit was deleting them upon being created much in the way my time lapse ones were. Obviously cameras setup on modect that had dropped events were harder to catch, because of the nature of modect, where perhaps, no one had noticed before that either the event never got created or sometimes got the ax.
I think that the default Phil set on MIN_AGE of 300 seconds does the job for modect and most setups unless perhaps if these events run long and not get enough time to gracefully end and close before zmaudit does its pass.
If for any reason someone finds out to have dropped events, of course first check de logs to see if these are being deleted by zmaudit, then you can fiddle with this MIN_AGE seconds and find out, like I did, to do the trick.
Regards!
