Windows Live Viewer..27-11-05 Now Complete Frontend for ZM!!
jameswilson
Post by jameswilson »
there is something wrong with your framework then on that machine, have you tried repairing the framework from add/remove programs
James Wilson
voronwe
Post by voronwe »
Hi James
I have done repair of both .Net 1.1 and 2.0 and it still dont work.
Do you have any other ideas i could try. ?
Best Regards
Tom Stage
jameswilson
i dont mate im afrid, if the test app i did wont run zm4ms has no chance. I dont know where to start to be honest it has to be something on tht machine that doesnt like me!!
You havnt had it on anything else? could you drop a new hd in it and build windows again just to test if its something on the old drive?
James Wilson
jameswilson
i have had a couple of emails about not being able to download from my website. Im sorry but i lost the old site and rebuilt this one too quicly in the mean time download the current version here
http://www.jpwilson.eu/version2/zm4msbeta.zip
i have a new version in test (no languge support as yet sorry lads) and will post that in the next week or so
James Wilson
goose202
Post by goose202 »
Hi James,
I have another quick feature request if it is easy to implement: I only just zm4ms to review events, not actually monitor what's happening in real time, so a option or command line switch to go straight to the screen you get by clicking the green square would be fantastic.
Thanks,
Bruce.
jameswilson
do you mean load up a particular monitor to playback using command line only?
James Wilson
goose202
Post by goose202 »
Yeah - wouldn't have to be command line only, that was just a suggestion on a way it could be done. An option to set to go straight to playback for a chosen monitor by default would achieve the same thing too.
I only have one camera so I didn't think about having to choose a particular monitor. :)
jameswilson
you do know about the green button in the view window dont you?
James Wilson
goose202
Post by goose202 »
Yeah that's what I normally use. It'd just be cool to be able to go straight there, that's all.
jameswilson
do you only use it for playback?
im wondering how much straighter you would like to get there thats all?
James Wilson
goose202
Post by goose202 »
Yes, only playback.
jameswilson
ok.
I dont want to add coomand line options due to the complexities of it, but i could have an option to load a playback window on a set cam on open i suppose. I will have a look
James Wilson
cdbao
Post by cdbao »
dear mr.jameswilson
Could you share your code of zm4ms
we can develop it some feature.
thanks and regard
jameswilson
this has come up many times, it is not an open souce app. My compnay paid me to develop it and wont open it. They will however allow freeware use of it.
What feature do you want?
James Wilson
cdbao
Post by cdbao »
Now we can develop schedule of state camera this feature is needed,and some module of language,"hot key" activition some basic feature (i had idea a project can use remote control through infared port).
Thanks and Regard
