Windows Live Viewer..27-11-05 Now Complete Frontend for ZM!!
KM
Error: Unable to connect to any of the mysql hosts
Post by KM »
Hello
Somebody has already posted this previously, but I get the following error in configuring zm on Win XP:
-Unable to connect to any of the mysql hosts.
I have checked the username and password in both mysql and Viseon Viewer to be correctly set to 'zmuser' and 'zmpass'. I have granted all access to zmuser in mysql.
I have .NET 3.0 installed on my machine. The monitor settings are as follows:
Cam 1 IP/URL: 192.168.103.164
Port: <blank>
Site Names: <unchecked>
URL*: <unchecked>
Under 'Paths' tab:
Live view path: C:\Foundation\Apache2.2\cgi-bin\nph-zms (this was originally '/cgi-bin/nph-zms')
Playback path: C:\zm\events (this was originally '/zm/events/)
I have ZoneMinder running fine on my Linux box where the settings are slightly different:
Remote Host Name: root:math225c@192.168.103.164
Remote Host Path: /axis-cgi/jpg/image.cgi?resolution=640x480
I have used the above settings in my Win box but I get the same error.
Note that when I click the OK button on the above error message, an exception message pops up saying :
__________________________________________
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at ViseonViewer2.mysql.Button2_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.PerformClick()
at ViseonViewer2.Cam2.PlayBut_Click(Object sender, EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
ViseonViewer2
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Documents%20and%20Settings/Administrator/Local%20Settings/Apps/2.0/QLTVPXCW.8XD/KYGHNAD2.MXT/vise..tion_0a282930b5e4c390_0001.0000_6f5da21aaa825d01/ViseonViewer2.exe
Microsoft.VisualBasic
Assembly Version: 8.0.0.0
Win32 Version: 8.0.50727.1433 (REDBITS.050727-1400)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Runtime.Remoting
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
System.Configuration
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
MySql.Data
Assembly Version: 5.0.6.0
Win32 Version: 5.0.6.0
CodeBase: file:///C:/Documents%20and%20Settings/Administrator/Local%20Settings/Apps/2.0/QLTVPXCW.8XD/KYGHNAD2.MXT/vise..tion_0a282930b5e4c390_0001.0000_6f5da21aaa825d01/MySql.Data.DLL
System.Data
CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
System.Transactions
CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Transactions/2.0.0.0__b77a5c561934e089/System.Transactions.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system>
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
___________________________________________________
I know that theres something trivial thats going wrong in my settings here. I would be glad if someone could point it out.
Please excuse me if I am asking the same questions again, but after going through the forums, I still havent been able to get this working.
-KM
jameswilson
Post by jameswilson »
These are definelty wrong
The default paths are for the live cd, if you are using other distro then you may need to modify your path to suit. Its the url path to images on the zm server. If you post your full url to jpeg images we can work out a path statement for you.
James
James Wilson
KM
Post by KM »
I do not have an images folder on my Win box. In Linux, the '--with-webdir=<>' option allowed us to specify a web dir where the images directory was automatically created by ZM. Viseon Viewer does not ask for any such option, hence the images dir too hasnt been created by ZM. That is why I manually created an images folder in the apache web server dir and gave this path to ZM.
Isnt ZM supposed to create a zm and cg-bin dir on its own on installation , the way it does on Linux ?
-KM
jameswilson
Is your zm installation working fully without zm?
zm4ms is purly an interface, it takes all the images and db etc from the zm server.
Trust me... i do know lol.
It will try and get images from for example
http://10.0.0.1/zm/nph-zms?blah blah balh.
Not C: anything.
Its the path statement that will need to be altere to suit your install. As i said its default settings are designed for the live cd. If your not using the live this will need to be modified to match your web directory strubcture on your zm box.
Just thought. Your not trying to use zm4ms as a full app, ie recorder etc without a linux zm?
James
James Wilson
KM
Post by KM »
There it goes. I thought zm4ms was an independent application. No wonder I was trying to look for a server installation on my Win machine without any success. Thought I had missed some setup or something.
Thanks for your help.
jameswilson
no problem
glad we got to the bottom of it!
James Wilson
Beofres
Errors when cycling camera or watching full-screen
Post by Beofres »
Hello!
Been using the viewer for awhile now, but it appears to be very...buggy at times. I'm trying to cycle 3 cameras and once it reaches the third camera I get an error message. It happens on a windows 2000 computer and on a windows xp box.
System.InvalidCastException: Conversion from string "" to type 'Integer' is not valid. ---> System.FormatException: Input string was not in a correct format.
   at Microsoft.VisualBasic.CompilerServices.Conversions.ParseDouble(String Value, NumberFormatInfo NumberFormat)
   at Microsoft.VisualBasic.CompilerServices.Conversions.ToInteger(String Value)
   --- End of inner exception stack trace ---
   at ViseonViewer2.sequenceView.Timer2_Tick(Object sender, EventArgs e)
   at System.Windows.Forms.Timer.OnTick(EventArgs e)
   at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
mscorlib
    Win32 Version: 2.0.50727.42 (RTM.050727-4200)
    CodeBase: file:///C:/WINNT/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
ViseonViewer2
    CodeBase: file:///C:/Documents%20and%20Settings/Administrator/Local%20Settings/Apps/2.0/67JD3882.A89/VJ0MZK7E.CHO/vise..tion_0a282930b5e4c390_0001.0000_3fb34866ca7eae65/ViseonViewer2.exe
    Win32 Version: 8.0.50727.42 (RTM.050727-4200)
    CodeBase: file:///C:/WINNT/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
    CodeBase: file:///C:/WINNT/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
    CodeBase: file:///C:/WINNT/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
    CodeBase: file:///C:/WINNT/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    CodeBase: file:///C:/WINNT/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
    CodeBase: file:///C:/WINNT/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
    CodeBase: file:///C:/WINNT/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
I also get this occasionally when in full screen:
   at ViseonViewer2.dualHead.Timer2_Tick(Object sender, EventArgs e)
mscorlib
    CodeBase: file:///c:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
ViseonViewer2
    CodeBase: file:///C:/Documents%20and%20Settings/Administrator/Local%20Settings/Apps/2.0/GDW45X38.13R/BYP1OQED.8J1/vise..tion_0a282930b5e4c390_0001.0000_65e9c797a89fee3f/ViseonViewer2.exe
System
System.Drawing
System.Xml
enabled.
For example:
<configuration>
</configuration>
Other than that, this application has great potential and I love it when it does work!
Thanks,
-Beofres
socsuser
Post by socsuser »
jameswilson wrote: It will try and get images from for example
James
Hi James, in my situation, for viewing a monitor the URL is:
http://zoneminder/zm/index.php?view=watch&mid=1
Now, this is quite different than your nph-zms controller that is listed above as it is using index.php and I can't help but figure that I'm missing something. Where can I find the proper URL for zm4ms?
Also, regarding each of the fields in the settings window, what should they be following the IP/URL? Such as Port, MON (assume Monitor Number?), Cam. Desc. is obvious, but what of Site Names (Enabled Checkbox)? Then there is the URL checkbox at the end as well, which is enigmatic to a degree... I've got it checked since I'm giving it a URL, but I'm getting a red X icon in the center of each camera image.
Then also, under the Playback tab, what should actually go here? It's not asking for an ip or hostname of the mysql server...
Seems that I'm missing some sort of critical instructions as I've not been able to find anything completely clear-cut or indicative here on the ZM Forums.
[EDIT]
Continuing on, I did find `/usr/share/zoneminder/cgi-bin/nph-zms`. What is to be done regarding these? It appears that this is found in the config as ZM_PATH_ZMS and is the streaming server and nph has to do with non-parsed header, however, what is to be done regarding this and passing it proper parameters, etc?
jameswilson
your path is wrong, that is the page path not the image path. When viewing if you select stills, then right click on the resulting image and view its properties this will give you your image path.
URL checkboxes are for 'URL MODE'. This uses the ip/url box as the whole setting so you can enter any valid jpeg url here and can be used for non zm purposes, webcams, weather cams etc.
Site names are used when using zm4ms to monitor several sites and the cam name will alternate with the site name. Thats all that does.
Playback, as zm4ms can request data from mutiple machines it assumes the ip address of the monitor you wish to view.
James Wilson
jameswilson
re the bug above, i havnt been able to replicate this, but if i do recall a similar issue many months ago. Can you create both custom views and see if this helps.
Will help me track it down, also if you know how to replicate it everytime this will help
James Wilson
nux
I couldn't see
Post by nux »
dear james,
first of all, thanks for your extraordinary work !
I have a zm working on one pc with only one monitor all is working ok
My setting in zm4ms in other machine are:
Paths:
Live View Path : http://ip_number_zm/cgi-bin/nph-zms
Data Type , http://ip_number_zm/cgi-bin/nph-zms
Playback Path http://ip_number_zm/zm/events
the paths are OK I verified from the zm4ms machine and others
but I couldn't see anything :-(
can you help me ?
thanks !
jameswilson
the paths shouldnt be changed and if so need to reflect the values for your zm server, ie if you have changed the directory structure.
To test use url mode on cam1 and past the full single url into the ip box.
ie connect to your zm box and view the non stream jpeg image, right click on the image to find its url and paste that into zm4ms.
Also disable auth on the zm box while you set it up.
James Wilson
nux
thanks
Post by nux »
yes !! it works !
thanks !
nux
Post by nux »
I am sure that I am making something in a bad way :-(
When I copied the url from image in the machine running zm, in the viewer I can only see the picture with a very slow refresh , I need to clic in a little blue rectnagle to have a stream.
i want to have stream when I open the application , without needing to click in anyplace
the url that I am using is like this:
http://nro_ip_zoneminder/cgi-bin/nph-zms?mode=single&monitor=2
can you help me ?
thanks !
jameswilson
you need to increase you refresh speed in the options.
Also using url mode isnt the best way.
Once your running put you path statement back to default and enter the ip only in the ip box.
If your running on port 80 leave the port blank, if not enter the port with a colon ie :82
James Wilson
