Shared memory not initialised by capture daemon
dannylco
Post by dannylco »
Hi all,
The log file have show this error message:
- shared memory not initialised by capture daemon
- Select timed out
- Waiting for capture daemon
I have set the shmall and shmmax as 268435456. How do i solve this problem?
zoneminder
Site Admin
Re: Shared memory not initialised by capture daemon
Post by zoneminder »
Hi Danny,
This message basically means that the analysis daemon does not believe that the capture daemon has started properly.
Can you give a few more details about your setup? Do you have any other errors in any of your log files?
Cheers,
Phil,
dannylco
Post by dannylco »
Thank Phil
finally i got work~~~, however there have other problem.
I am using Redhat 9 and Kodak EZ200 camera.
1. When I open the camera there is no streaming real-time feeds. My client is using IE6. Do I need to install or config something in my client side? However, i can preview the streaming event.
2. When I click "Stills", there is no picture. I think is the frequency too fast. Could you tell me where i can reduce the frequency?
3. Wheb I click 'stills' from the event, the little box is no picture. Do I need to install some component?
Regards
