Page 1 of 1
Posted: Sun Aug 12, 2007 5:02 pm
by cyrulution
I got one of these cheap Chinese cards from ebay:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0152351656
I tried xawtv and this is the result:
This is xawtv-3.95, running on Linux/i686 (2.6.17-10mdv)
can't open /dev/video0: No such file or directory
v4l-conf had some trouble, trying to continue anyway
v4l2: open /dev/video0: No such file or directory
v4l: open /dev/video0: No such file or directory
no video grabber device available
As I'm new to ZM I don't know what to do now.
Help!
Cyrus
Posted: Sun Aug 12, 2007 6:48 pm
by Lee Sharp
You have not detected the card yet. Post your dmesg and lspci please.
Posted: Sun Aug 12, 2007 8:14 pm
by cyrulution
Lee Sharp wrote:You have not detected the card yet. Post your dmesg and lspci please.
Kate says lspci in /usr/bin/ is an executable and shows a lot of cryptic signs
Here is dmesg from /var/log/:
Linux version 2.6.17-10mdv (qateam@mercury.mandriva.com) (gcc version 4.1.1 20060724 (prerelease) (4.1.1-3mdk)) #1 SMP Fri Feb 2 15:53:02 MST 2007
BIOS-provided physical RAM map:
BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
BIOS-e820: 0000000000100000 - 0000000017fec000 (usable)
BIOS-e820: 0000000017fec000 - 0000000017fef000 (ACPI data)
BIOS-e820: 0000000017fef000 - 0000000017fff000 (reserved)
BIOS-e820: 0000000017fff000 - 0000000018000000 (ACPI NVS)
BIOS-e820: 00000000ffff0000 - 0000000100000000 (reserved)
0MB HIGHMEM available.
383MB LOWMEM available.
On node 0 totalpages: 98284
DMA zone: 4096 pages, LIFO batch:0
Normal zone: 94188 pages, LIFO batch:31
DMI 2.3 present.
ACPI: RSDP (v000 ASUS ) @ 0x000f5aa0
ACPI: RSDT (v001 ASUS CUBX 0x30303031 MSFT 0x31313031) @ 0x17fec000
ACPI: FADT (v001 ASUS CUBX 0x30303031 MSFT 0x31313031) @ 0x17fec080
ACPI: BOOT (v001 ASUS CUBX 0x30303031 MSFT 0x31313031) @ 0x17fec040
ACPI: DSDT (v001 ASUS CUBX 0x00001000 MSFT 0x0100000b) @ 0x00000000
ACPI: PM-Timer IO Port: 0xe408
Allocating PCI resources starting at 20000000 (gap: 18000000:e7ff0000)
Built 1 zonelists
Kernel command line: root=/dev/hda1 splash=silent vga=788
bootsplash: silent mode.
Local APIC disabled by BIOS -- you can enable it with "lapic"
mapped APIC to ffffe000 (0130a000)
Enabling fast FPU save and restore... done.
Enabling unmasked SIMD FPU exception support... done.
Initializing CPU#0
PID hash table entries: 2048 (order: 11, 8192 bytes)
Detected 798.073 MHz processor.
Using pmtmr for high-res timesource
Console: colour dummy device 80x25
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 384364k/393136k available (2427k kernel code, 7752k reserved, 755k data, 244k init, 0k highmem, 0k BadRAM)
Checking if this processor honours the WP bit even in supervisor mode... Ok.
Calibrating delay using timer specific routine.. 1597.43 BogoMIPS (lpj=3194879)
Mount-cache hash table entries: 512
CPU: After generic identify, caps: 0383f9ff 00000000 00000000 00000000 00000000 00000000 00000000
CPU: After vendor identify, caps: 0383f9ff 00000000 00000000 00000000 00000000 00000000 00000000
CPU: L1 I cache: 16K, L1 D cache: 16K
CPU: L2 cache: 256K
CPU: After all inits, caps: 0383f9ff 00000000 00000000 00000040 00000000 00000000 00000000
Intel machine check architecture supported.
Intel machine check reporting enabled on CPU#0.
Checking 'hlt' instruction... OK.
SMP alternatives: switching to UP code
Freeing SMP alternatives: 16k freed
checking if image is initramfs... it is
Freeing initrd memory: 350k freed
ACPI: Looking for DSDT in initramfs... error, file /DSDT.aml not found.
ACPI: setting ELCR to 0200 (from 0a00)
CPU0: Intel Pentium III (Coppermine) stepping 06
SMP motherboard not detected.
Local APIC not detected. Using dummy APIC emulation.
Brought up 1 CPUs
migration_cost=0
NET: Registered protocol family 16
ACPI: bus type pci registered
PCI: PCI BIOS revision 2.10 entry at 0xf08c0, last bus=1
Setting up standard PCI resources
ACPI: Subsystem revision 20060127
ACPI: Interpreter enabled
ACPI: Using PIC for interrupt routing
ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 9 10 *11 12 14 15)
ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 9 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 9 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 *9 10 11 12 14 15)
ACPI: PCI Root Bridge [PCI0] (0000:00)
PCI: Probing PCI hardware (bus 00)
ACPI: Assume root bridge [\_SB_.PCI0] bus is 0
PCI quirk: region e400-e43f claimed by PIIX4 ACPI
PCI quirk: region e800-e80f claimed by PIIX4 SMB
Boot video device is 0000:01:00.0
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
Linux Plug and Play Support v0.97 (c) Adam Belay
pnp: PnP ACPI init
pnp: PnP ACPI: found 14 devices
PnPBIOS: Disabled
PCI: Using ACPI for IRQ routing
PCI: If a device doesn't work, try "pci=routeirq". If it helps, post a report
PCI: BIOS reporting unknown device 00:68
PCI: Device 0000:00:0d.1 not found by BIOS
pnp: 00:03: ioport range 0xe400-0xe43f could not be reserved
pnp: 00:03: ioport range 0xe800-0xe80f has been reserved
PCI: Bridge: 0000:00:01.0
IO window: disabled.
MEM window: e0000000-e1dfffff
PREFETCH window: e1f00000-e3ffffff
NET: Registered protocol family 2
IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
TCP established hash table entries: 16384 (order: 5, 131072 bytes)
TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 16384 bind 8192)
TCP reno registered
Simple Boot Flag at 0x3a set to 0x1
* Found PM-Timer Bug on this chipset. Due to workarounds for a bug,
* this time source is slow. Consider trying other time sources (clock=)
apm: BIOS version 1.2 Flags 0x03 (Driver version 1.16ac)
apm: overridden by ACPI.
audit: initializing netlink socket (disabled)
audit(1186937104.708:1): initialized
Total HugeTLB memory allocated, 0
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Initializing Cryptographic API
io scheduler noop registered
io scheduler anticipatory registered (default)
io scheduler deadline registered
io scheduler cfq registered
Limiting direct PCI/PCI transfers.
vesafb: framebuffer at 0xe2000000, mapped to 0xd8880000, using 3750k, total 4096k
vesafb: mode is 800x600x16, linelength=1600, pages=3
vesafb: protected mode interface info at c000:0361
vesafb: scrolling: redraw
vesafb: Truecolor: size=0:5:6:5, shift=0:11:5:0
bootsplash 3.1.6-2004/03/31: looking for picture...<6> silentjpeg size 13182 bytes,<6>...found (800x600, 9805 bytes, v3).
Console: switching to colour frame buffer device 100x37
fb0: VESA VGA frame buffer device
isapnp: Scanning for PnP cards...
isapnp: No Plug & Play device found
Real Time Clock Driver v1.12ac
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
00:0a: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
00:0b: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
RAMDISK driver initialized: 16 RAM disks of 32000K size 1024 blocksize
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
PIIX4: IDE controller at PCI slot 0000:00:04.1
PIIX4: chipset revision 1
PIIX4: not 100% native mode: will probe irqs later
ide0: BM-DMA at 0xd800-0xd807, BIOS settings: hda:DMA, hdb:DMA
ide1: BM-DMA at 0xd808-0xd80f, BIOS settings: hdc:pio, hdd:pio
Probing IDE interface ide0...
hda: WDC WD800BB-00JHC0, ATA DISK drive
hdb: HL-DT-ST RW/DVD GCC-4520B, ATAPI CD/DVD-ROM drive
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
Probing IDE interface ide1...
hda: max request size: 128KiB
hda: 156301488 sectors (80026 MB) w/2048KiB Cache, CHS=65535/16/63, UDMA(33)
hda: cache flushes supported
hda: hda1 hda2 < hda5 hda6 hda7 >
PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
serio: i8042 AUX port at 0x60,0x64 irq 12
serio: i8042 KBD port at 0x60,0x64 irq 1
mice: PS/2 mouse device common for all mice
md: md driver 0.90.3 MAX_MD_DEVS=256, MD_SB_DISKS=27
md: bitmap version 4.39
TCP bic registered
Using IPI No-Shortcut mode
ACPI wakeup devices:
PCI0 UAR1 UAR2 PS2K PS2M USB0
ACPI: (supports S0 S1 S4 S5)
BIOS EDD facility v0.16 2004-Jun-25, 1 devices found
Freeing unused kernel memory: 244k freed
input: AT Translated Set 2 keyboard as /class/input/input0
SCSI subsystem initialized
libata version 1.20 loaded.
input: ImPS/2 Logitech Wheel Mouse as /class/input/input1
ts: Compaq touchscreen protocol output
usbcore: registered new driver usbfs
usbcore: registered new driver hub
USB Universal Host Controller Interface driver v3.0
ACPI: PCI Interrupt Link [LNKD] enabled at IRQ 9
PCI: setting IRQ 9 as level-triggered
ACPI: PCI Interrupt 0000:00:04.2[D] -> Link [LNKD] -> GSI 9 (level, low) -> IRQ 9
uhci_hcd 0000:00:04.2: UHCI Host Controller
uhci_hcd 0000:00:04.2: new USB bus registered, assigned bus number 1
uhci_hcd 0000:00:04.2: irq 9, io base 0x0000d400
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
PCI: Enabling device 0000:00:0d.0 (0014 -> 0015)
ACPI: PCI Interrupt 0000:00:0d.0[A] -> Link [LNKD] -> GSI 9 (level, low) -> IRQ 9
PCI: VIA IRQ fixup for 0000:00:0d.0, from 255 to 9
uhci_hcd 0000:00:0d.0: UHCI Host Controller
uhci_hcd 0000:00:0d.0: new USB bus registered, assigned bus number 2
uhci_hcd 0000:00:0d.0: irq 9, io base 0x0000b400
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
PCI: Enabling device 0000:00:0d.1 (0014 -> 0015)
ACPI: PCI Interrupt Link [LNKA] enabled at IRQ 11
PCI: setting IRQ 11 as level-triggered
ACPI: PCI Interrupt 0000:00:0d.1 -> Link [LNKA] -> GSI 11 (level, low) -> IRQ 11
PCI: VIA IRQ fixup for 0000:00:0d.1, from 255 to 11
uhci_hcd 0000:00:0d.1: UHCI Host Controller
uhci_hcd 0000:00:0d.1: new USB bus registered, assigned bus number 3
uhci_hcd 0000:00:0d.1: irq 11, io base 0x0000b000
usb usb3: configuration #1 chosen from 1 choice
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 2 ports detected
usb 2-1: new full speed USB device using uhci_hcd and address 2
usb 2-1: configuration #1 chosen from 1 choice
hub 2-1:1.0: USB hub found
hub 2-1:1.0: 7 ports detected
PCI: Enabling device 0000:00:0d.2 (0014 -> 0016)
ACPI: PCI Interrupt Link [LNKB] enabled at IRQ 11
ACPI: PCI Interrupt 0000:00:0d.2[C] -> Link [LNKB] -> GSI 11 (level, low) -> IRQ 11
ehci_hcd 0000:00:0d.2: EHCI Host Controller
ehci_hcd 0000:00:0d.2: new USB bus registered, assigned bus number 4
ehci_hcd 0000:00:0d.2: irq 11, io mem 0xdd800000
ehci_hcd 0000:00:0d.2: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
usb usb4: configuration #1 chosen from 1 choice
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 4 ports detected
usb 2-1: USB disconnect, address 2
usb 2-1: new full speed USB device using uhci_hcd and address 3
sonypi: Sony Programmable I/O Controller Driver v1.26.
Linux agpgart interface v0.101 (c) Dave Jones
agpgart: Detected an Intel 440BX Chipset.
agpgart: AGP aperture is 64M @ 0xe4000000
device-mapper: 4.6.0-ioctl (2006-02-17) initialised: dm-devel@redhat.com
Adding 4088500k swap on /dev/hda5. Priority:-1 extents:1 across:4088500k
kjournald starting. Commit interval 5 seconds
EXT3 FS on hda6, internal journal
EXT3-fs: mounted filesystem with ordered data mode.
EXT3 FS on hda7, internal journal
loop: loaded (max 8 devices, max 1 partitions per device)
hdb: ATAPI 52X DVD-ROM CD-R/RW drive, 2048kB Cache, UDMA(33)
Uniform CD-ROM driver Revision: 3.20
thanks
Posted: Mon Aug 13, 2007 12:58 am
by rodj59
Execute lspci: it shows the installed pci devices. Could also try modprobe bt878 &/or lsmod.
Posted: Mon Aug 13, 2007 6:03 am
by cyrulution
rodj59 wrote:Execute lspci: it shows the installed pci devices. Could also try modprobe bt878 &/or lsmod.
here it is:
[cyrus ~]$ lspci
00:00.0 Host bridge: Intel Corporation 440BX/ZX/DX - 82443BX/ZX/DX Host bridge (rev 03)
00:01.0 PCI bridge: Intel Corporation 440BX/ZX/DX - 82443BX/ZX/DX AGP bridge (rev 03)
00:04.0 ISA bridge: Intel Corporation 82371AB/EB/MB PIIX4 ISA (rev 02)
00:04.1 IDE interface: Intel Corporation 82371AB/EB/MB PIIX4 IDE (rev 01)
00:04.2 USB Controller: Intel Corporation 82371AB/EB/MB PIIX4 USB (rev 01)
00:04.3 Bridge: Intel Corporation 82371AB/EB/MB PIIX4 ACPI (rev 02)
00:09.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+ (rev 10)
00:0a.0 Multimedia video controller: JumpTec h, GMBH Unknown device 6800 (rev 11)
00:0c.0 Multimedia audio controller: Ensoniq ES1370 [AudioPCI]
00:0d.0 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 61)
00:0d.1 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 61)
00:0d.2 USB Controller: VIA Technologies, Inc. USB 2.0 (rev 63)
01:00.0 VGA compatible controller: nVidia Corporation NV5M64 [RIVA TNT2 Model 64/Model 64 Pro] (rev 15)
Isn't it the "unknown device 6800"?
Posted: Mon Aug 13, 2007 2:18 pm
by Lee Sharp
This is it. Unfortunately, Google has found nothing for me. Anyone else?
Posted: Mon Aug 13, 2007 7:18 pm
by cordel
Nope i got the same thing, the only entry in the kernel is the pci-id.
Would seem that this card is not supported by linux at this time.
Posted: Mon Aug 13, 2007 7:29 pm
by neilk
JUMPtec Industrielle Computertechnik AG and Kontron Embedded Computers AG merged in
July 2002. JUMPtec is now known as Kontron Embedded Modules GmbH. Products labeled
and sold under the Kontron Embedded Modules name (formerly JUMPtec) are now
considered Kontron products for all practical purposes, including warranty and support.
