Wanna try ZM, but have fallen at the first hurdle
Have installed the ZM 1.22.3-7.fc7.i386 RPM via yum.
Installed apache and mysql no worries.
Following the install instructions in the docs, it says I need to run:
/usr/lib/zm/bin/zminit
in order to create the zm database. Problem is, I don't have a /usr/lib/zm folder, and even searching the entire disk for zminit throws up a blank.
HELP!
