Page 1 of 1
Motion detection problem
Posted: Thu Aug 23, 2007 8:10 am
by blight
Hi Everyone
I am having a problem with the motion detection in zoneminder.
I have a linksys WVC54GC and followed the information in thread:
http://www.zoneminder.com/forums/viewto ... e2334d2589
However when motion detection is enabled, every now and then, it triggers on the 11th image out of 21 where the image is half grey (Almost as if it is in the process of refreshing)
It doesnt trigger on actualy motion (Only on this grey section)
I will post image if necessary
I have tried different options and presets in the zones but with no luck.
Your assistance would be greatly appreciated
Regards
Brendon
Posted: Thu Aug 23, 2007 7:43 pm
by Lee Sharp
This is an image capture problem. If you can't figure out a way to fix the occasional flashing frame, you will have to change the settings to 3 consecutive alarm frames to trip alarm.
