help with user authenticated mode
nabetse_x
Post by nabetse_x »
hi, i'm a newbie on zoneminder, and i have readed and searched on the forums/faqs/readmes, and i couldn't find anything about my problem.
After i have all my monitors configured without any problems, i decide to start to use the user auth feature, using ZM_OPT_USE_AUTH = builtin and ZM_AUTH_RELAY= hashed , and then i decide to try with user admin. the authentication it's alright, but when i open any monitor (i have 16 monitors) , no streams appears, only appears the border and the name of the monitor inside with an image on the top-left corner. The first time this happens i added the user www-data at groups root and video and works without problems. but now doesn't work...
please help me.
P.S.: sorry if my english it's not good, but im chilean, and i cant speak english, but im learning....
regards,
Esteban
San Francisco Mostazal
Chile
Lee Sharp
Post by Lee Sharp »
Known issue. Try plain.
nabetse_x
Post by nabetse_x »
it works,, thanks man.....and to continue trying this excelent software...
my boss will thanks....
cyrulution
Post by cyrulution »
Lee Sharp wrote:Known issue. Try plain.
Got the same problem and - stupid as I am :oops: - I don't know:
Where, what kind of "plain"?
Sorry!
... for bothering - I found the solution, just in the same tab of the options, where I enabled the authentication ...
Cyrus
Serenity is not freedom from storm; it's peace within the storm
Laevi
Post by Laevi »
switch option ZM_AUTH_RELAY to 'plain' under system settings
