Removing Monitors
neilk
Removing Monitors
Post by neilk »
This may be posted in the wrong area.sorry
I have a small problem , i installed a second capture card and added two new monitors /dev/video1(0) and /dev/video1(1) on the ZM console .
how do i delete or remove them from the config to stop them showing up in the Montage. so i have 4 live monitors and not the 2 none used ones on my second card as showing up as well .
i tired to remove them via editing the /dev/video1 but they still show up ?
By BigMaxIOM
i cant find any info in the FAC's or the Wiki about this .
Thank you. :?
jameswilson
Post by jameswilson »
on the right you see some checkbox's
select em then press delete
James Wilson
neilk
Post by neilk »
you know if my brain was working today , i might have seen that !!!!
Thanks James :oops:
jameswilson
lol
James Wilson
