[Solved] No camera image is displayed, only a blank screen
Posted: Sat Sep 01, 2007 8:34 pm
i am using zoneminder for several months, but now i want to set up a own dedicated server with a 16 port capture card (Kodicom 4400R), running Gentoo Linux 2007.0 with kernel 2.6.19-gentoo-r5
I added
as mentioned in the forum, and with xawtv i can display videos - but only when I use the "grabdisplay" mode. Zoneminder displays only the blue screen, but no video.
Am I missing some options in the kernel? Can Zoneminder use the grabdisplay mode?
This is the output of lspci -v
"dmesg | grep bttv" says
modinfo bttv
ipcs -m
Logfile zmaudit.log
zmdc.log
zmtrigger.log
I hope that I don't have forgotten anything...
I added
alias char-major-81 bttv
options bttv gbuffers=16 card=133,132,133,133
00:00.0 Host bridge: VIA Technologies, Inc. VT8366/A/7 [Apollo KT266/A/333]
Subsystem: ASUSTeK Computer Inc. A7V333 Mainboard
Flags: bus master, 66MHz, medium devsel, latency 0
Memory at e0000000 (32-bit, prefetchable) [size=64M]
Capabilities: [a0] AGP version 2.0
Capabilities: [c0] Power Management version 2
00:01.0 PCI bridge: VIA Technologies, Inc. VT8366/A/7 [Apollo KT266/A/333 AGP] (prog-if 00 [Normal decode])
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
Memory behind bridge: d2800000-d36fffff
Prefetchable memory behind bridge: d7f00000-dfffffff
Capabilities: [80] Power Management version 2
00:05.0 Multimedia audio controller: C-Media Electronics Inc CM8738 (rev 10)
Subsystem: ASUSTeK Computer Inc. CMI8738 6ch-MX
Flags: bus master, stepping, medium devsel, latency 32, IRQ 10
I/O ports at d800 [size=256]
00:09.0 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 50) (prog-if 00 [UHCI])
Subsystem: ASUSTeK Computer Inc. A7V333 motherboard
Flags: bus master, medium devsel, latency 32, IRQ 16
I/O ports at d400 [size=32]
00:09.1 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 50) (prog-if 00 [UHCI])
Flags: bus master, medium devsel, latency 32, IRQ 18
I/O ports at d000 [size=32]
00:09.2 USB Controller: VIA Technologies, Inc. USB 2.0 (rev 51) (prog-if 20 [EHCI])
Subsystem: ASUSTeK Computer Inc. Unknown device 8080
Flags: bus master, medium devsel, latency 32, IRQ 17
Memory at d2000000 (32-bit, non-prefetchable) [size=256]
00:0e.0 PCI bridge: Hint Corp HB6 Universal PCI-PCI bridge (non-transparent mode) (rev 11) (prog-if 00 [Normal decode])
Bus: primary=00, secondary=02, subordinate=02, sec-latency=32
Prefetchable memory behind bridge: d3800000-d7efffff
Capabilities: [90] #06 [0000]
00:10.0 Ethernet controller: 3Com Corporation 3c905C-TX/TX-M [Tornado] (rev 78)
Subsystem: 3Com Corporation 3C905C-TX Fast Etherlink for PC Management NIC
I/O ports at b800 [size=128]
Memory at d1800000 (32-bit, non-prefetchable) [size=128]
[virtual] Expansion ROM at 30000000 [disabled] [size=128K]
Capabilities: [dc] Power Management version 2
00:11.0 ISA bridge: VIA Technologies, Inc. VT8233A ISA Bridge
Flags: bus master, stepping, medium devsel, latency 0
00:11.1 IDE interface: VIA Technologies, Inc. VT82C586A/B/VT82C686/A/B/VT823x/A/C PIPC Bus Master IDE (rev 06) (prog-if 8a [Master SecP PriP])
Subsystem: ASUSTeK Computer Inc. A7V8X / A7V333 motherboard
I/O ports at b400 [size=16]
00:11.2 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 23) (prog-if 00 [UHCI])
Subsystem: ASUSTeK Computer Inc. VT6202 USB2.0 4 port controller
Flags: bus master, medium devsel, latency 32, IRQ 19
I/O ports at b000 [size=32]
00:11.3 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 23) (prog-if 00 [UHCI])
I/O ports at a800 [size=32]
01:00.0 VGA compatible controller: S3 Inc. Savage 4 (rev 02) (prog-if 00 [VGA])
Subsystem: Elsa AG Unknown device 0974
Flags: bus master, 66MHz, medium devsel, latency 64, IRQ 11
Memory at d2800000 (32-bit, non-prefetchable) [size=512K]
Memory at d8000000 (32-bit, prefetchable) [size=128M]
Expansion ROM at d7ff0000 [disabled] [size=64K]
Capabilities: [dc] Power Management version 1
Capabilities: [80] AGP version 2.0
02:0c.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
Memory at d7000000 (32-bit, prefetchable) [size=4K]
Capabilities: [44] Vital Product Data
Capabilities: [4c] Power Management version 2
02:0c.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
Memory at d6800000 (32-bit, prefetchable) [size=4K]
02:0d.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
Flags: bus master, medium devsel, latency 32, IRQ 20
Memory at d6000000 (32-bit, prefetchable) [size=4K]
02:0d.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
Memory at d5800000 (32-bit, prefetchable) [size=4K]
02:0e.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
Memory at d5000000 (32-bit, prefetchable) [size=4K]
02:0e.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
Memory at d4800000 (32-bit, prefetchable) [size=4K]
02:0f.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
Memory at d4000000 (32-bit, prefetchable) [size=4K]
02:0f.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
Memory at d3800000 (32-bit, prefetchable) [size=4K]
bttv: driver version 0.9.16 loaded
bttv: using 16 buffers with 2080k (520 pages) each for capture
bttv: Bt8xx card found (0).
bttv0: Bt878 (rev 17) at 0000:02:0c.0, irq: 17, latency: 32, mmio: 0xd7000000
bttv0: using: Kodicom 4400R (slave) [card=133,insmod option]
bttv0: gpio: en=00000000, out=00000000 in=00ffffff [init]
bttv0: using tuner=-1
bttv0: i2c: checking for TDA9887 @ 0x86... not found
bttv0: registered device video0
bttv0: registered device vbi0
bttv0: PLL: 28636363 => 35468950 .. ok
bttv: Bt8xx card found (1).
bttv1: Bt878 (rev 17) at 0000:02:0d.0, irq: 20, latency: 32, mmio: 0xd6000000
bttv1: using: Kodicom 4400R (master) [card=132,insmod option]
bttv1: gpio: en=00000000, out=00000000 in=00ffffff [init]
bttv1: using tuner=-1
bttv1: i2c: checking for TDA9887 @ 0x86... not found
bttv1: registered device video1
bttv1: registered device vbi1
bttv1: PLL: 28636363 => 35468950 .. ok
bttv: Bt8xx card found (2).
bttv2: Bt878 (rev 17) at 0000:02:0e.0, irq: 16, latency: 32, mmio: 0xd5000000
bttv2: using: Kodicom 4400R (slave) [card=133,insmod option]
bttv2: gpio: en=00000000, out=00000000 in=00ffffff [init]
bttv2: using tuner=-1
bttv2: i2c: checking for TDA9887 @ 0x86... not found
bttv2: registered device video2
bttv2: registered device vbi2
bttv2: PLL: 28636363 => 35468950 .. ok
bttv: Bt8xx card found (3).
bttv3: Bt878 (rev 17) at 0000:02:0f.0, irq: 18, latency: 32, mmio: 0xd4000000
bttv3: using: Kodicom 4400R (slave) [card=133,insmod option]
bttv3: gpio: en=00000000, out=00000000 in=00ffffff [init]
bttv3: using tuner=-1
bttv3: i2c: checking for TDA9887 @ 0x86... not found
bttv3: registered device video3
bttv3: registered device vbi3
bttv3: PLL: 28636363 => 35468950 .. ok
filename: /lib/modules/2.6.19-gentoo-r5/kernel/drivers/media/video/bt8xx/bttv.ko
description: bttv - v4l/v4l2 driver module for bt848/878 based cards
author: Ralph Metzler & Marcus Metzler & Gerd Knorr
license: GPL
vermagic: 2.6.19-gentoo-r5 SMP mod_unload K7 REGPARM
depends: video-buf,ir-common,tveeprom,btcx-risc
alias: pci:v0000109Ed00000350sv*sd*bc*sc*i*
alias: pci:v0000109Ed00000351sv*sd*bc*sc*i*
alias: pci:v0000109Ed0000036Esv*sd*bc*sc*i*
alias: pci:v0000109Ed0000036Fsv*sd*bc*sc*i*
parm: rc5_key_timeout:int
parm: rc5_remote_gap:int
parm: repeat_period:int
parm: repeat_delay:int
parm: debug:int
parm: i2c_udelay:soft i2c delay at insmod time, in usecs (should be 5 or higher). Lower value means higher bus speed. (int)
parm: i2c_scan:scan i2c bus at insmod time (int)
parm: i2c_hw:force use of hardware i2c support, instead of software bitbang (int)
parm: i2c_debug:int
parm: vbi_debug:vbi code debug messages, default is 0 (no) (int)
parm: vbibufs:number of vbi buffers, range 2-32, default 4 (int)
parm: audiomux:array of int
parm: remote:array of int
parm: svhs:array of int
parm: tuner:specify installed tuner type (array of int)
parm: pll:specify installed crystal (0=none, 28=28 MHz, 35=35 MHz) (array of int)
parm: card:specify TV/grabber card model, see CARDLIST file for a list (array of int)
parm: autoload:automatically load i2c modules like tuner.o, default is 1 (yes) (int)
parm: audioall:int
parm: gpiomask:int
parm: latency:pci latency timer (int)
parm: no_overlay:allow override overlay default (0 disables, 1 enables) [some VIA/SIS chipsets are known to have problem with overlay] (int)
parm: vsfx:set VSFX pci config bit [yet another chipset flaw workaround] (int)
parm: triton1:set ETBF pci config bit [enable bug compatibility for triton1 + others] (int)
parm: radio:The TV card supports radio, default is 0 (no) (array of int)
parm: coring:set the luma coring level, default is 0 (no) (int)
parm: full_luma_range:use the full luma range, default is 0 (no) (int)
parm: uv_ratio:ratio between u and v gains, default is 50 (int)
parm: vcr_hack:enables the VCR hack (improves synch on poor VCR tapes), default is 0 (no) (int)
parm: whitecrush_lower:sets the white crush lower value, default is 127 (int)
parm: whitecrush_upper:sets the white crush upper value, default is 207 (int)
parm: adc_crush:enables the luminance ADC crush, default is 1 (yes) (int)
parm: chroma_agc:enables the AGC of chroma signal, default is 0 (no) (int)
parm: automute:mute audio on bad/missing video signal, default is 1 (yes) (int)
parm: lumafilter:int
parm: combfilter:int
parm: irq_iswitch:switch inputs in irq handler (int)
parm: bigendian:byte order of the framebuffer, default is native endian (int)
parm: v4l2:int
parm: gbufsize:size of the capture buffers, default is 0x208000 (int)
parm: gbuffers:number of capture buffers. range 2-32, default 8 (int)
parm: vbi_nr:int
parm: radio_nr:int
parm: video_nr:int
parm: fdsr:int
parm: debug_latency:int
parm: irq_debug:irq handler debug messages, default is 0 (no) (int)
parm: bttv_debug:debug messages, default is 0 (no) (int)
parm: bttv_gpio:log gpio changes, default is 0 (no) (int)
parm: bttv_verbose:verbose startup messages, default is 1 (yes) (int)
------ Shared Memory Segments --------
key shmid owner perms bytes nattch status
0x7a6d2001 294912 apache 700 12166308 1
0x00000000 98305 apache 700 12166308 1 dest
0x7a6d2002 327682 apache 700 3073188 1
0x7a6d2005 360451 apache 700 3073188 1
0x7a6d2003 393220 apache 700 3073188 1
0x7a6d2006 425989 apache 700 3073188 1
0x7a6d2004 458758 apache 700 3073188 1
Logfile zmaudit.log
09/02/07 00:23:25.387135 zmaudit[9346].DBG [Found database monitor '1']
09/02/07 00:23:25.388545 zmaudit[9346].DBG [Got 0 events]
09/02/07 00:23:25.395482 zmaudit[9346].DBG [Found filesystem monitor '1']
09/02/07 00:23:25.395926 zmaudit[9346].DBG [Got 0 events]
09/02/07 00:23:25.396100 zmaudit[9346].DBG [Found filesystem monitor '2']
09/02/07 00:23:25.396360 zmaudit[9346].DBG [Got 0 events]
09/02/07 00:23:18.064770 zmdc[9298].INF [Server starting at 07/09/02 00:23:18]
09/02/07 00:23:21.467373 zmdc[9298].INF ['zmc -d /dev/v4l/video0' starting at 07/09/02 00:23:21, pid = 9321]
09/02/07 00:23:21.923528 zmdc[9298].INF ['zmc -d /dev/video1' starting at 07/09/02 00:23:21, pid = 9325]
09/02/07 00:23:22.387036 zmdc[9298].INF ['zmc -d /dev/video2' starting at 07/09/02 00:23:22, pid = 9329]
09/02/07 00:23:22.847172 zmdc[9298].INF ['zmc -d /dev/video3' starting at 07/09/02 00:23:22, pid = 9333]
09/02/07 00:23:23.299126 zmdc[9298].INF ['zmc -d /dev/video1' already running at 07/09/02 00:23:21, pid = 9325]
09/02/07 00:23:23.692361 zmdc[9298].INF ['zmc -d /dev/video2' already running at 07/09/02 00:23:22, pid = 9329]
09/02/07 00:23:24.086830 zmdc[9298].INF ['zmfilter.pl' starting at 07/09/02 00:23:24, pid = 9341]
09/02/07 00:23:25.006968 zmdc[9298].INF ['zmaudit.pl -c' starting at 07/09/02 00:23:25, pid = 9346]
09/02/07 00:23:25.771105 zmdc[9298].INF ['zmtrigger.pl' starting at 07/09/02 00:23:25, pid = 9351]
09/02/07 00:23:26.206358 zmdc[9298].ERR ['zmtrigger.pl ' exited abnormally, exit status 9]
09/02/07 00:23:26.207430 zmdc[9298].INF [Starting pending process, zmtrigger.pl]
09/02/07 00:23:26.218607 zmdc[9298].INF ['zmtrigger.pl' starting at 07/09/02 00:23:26, pid = 9354]
09/02/07 00:23:26.636860 zmdc[9298].ERR ['zmtrigger.pl ' exited abnormally, exit status 9]
09/02/07 00:23:27.006757 zmdc[9298].INF ['zmwatch.pl' starting at 07/09/02 00:23:27, pid = 9359]
09/02/07 00:23:27.718530 zmdc[9298].INF ['zmupdate.pl -c' starting at 07/09/02 00:23:27, pid = 9363]
09/02/07 00:23:31.069918 zmdc[9298].INF [Starting pending process, zmtrigger.pl]
09/02/07 00:23:31.074352 zmdc[9298].INF ['zmtrigger.pl' starting at 07/09/02 00:23:31, pid = 9380]
09/02/07 00:23:31.512725 zmdc[9298].ERR ['zmtrigger.pl ' exited abnormally, exit status 9]
09/02/07 00:23:41.020978 zmdc[9298].INF [Starting pending process, zmtrigger.pl]
09/02/07 00:23:41.025428 zmdc[9298].INF ['zmtrigger.pl' starting at 07/09/02 00:23:41, pid = 9384]
09/02/07 00:23:41.460322 zmdc[9298].ERR ['zmtrigger.pl ' exited abnormally, exit status 9]
09/02/07 00:24:01.074629 zmdc[9298].INF [Starting pending process, zmtrigger.pl]
09/02/07 00:24:01.087325 zmdc[9298].INF ['zmtrigger.pl' starting at 07/09/02 00:24:01, pid = 9388]
09/02/07 00:24:01.512944 zmdc[9298].ERR ['zmtrigger.pl ' exited abnormally, exit status 9]
09/02/07 00:23:26.188891 zmtrigger[9351].INF [Trigger daemon starting]
09/02/07 00:23:26.192112 zmtrigger[9351].INF [Opening connection 'Chan1']
09/02/07 00:23:26.193835 zmtrigger[9351].INF [Opening connection 'Chan2']
09/02/07 00:23:26.195209 zmtrigger[9351].INF [Opening connection 'Chan4']
09/02/07 00:23:26.620563 zmtrigger[9354].INF [Trigger daemon starting]
