Potential issues/sugesstions in zm_config.cpp
snakebyte
Post by snakebyte »
On line 52:
cfg_value.boolean_value = strtol( value, 0, 2 );
boolean_value will incorrectly come up as TRUE if value equals "-1".
possible fix:
long tmp=strtol( value, 0, 2 );
if ( (1 == tmp) )
cfg_value.boolean_value = true;
else
cfg_value.boolean_value = false;
On line 67:
cfg_value.decimal_value = atof( value );
suggest using strtod instead of atof because of the min/max boundry protection:
cfg_value.decimal_value = strtod( value, 0 );
On line 154:
n_items = mysql_num_rows( result );
Depending, mysql_num_rows can return anything from an unsigned long to an unsigned int64. n_items will incorrectly go negative if anything above 0x7FFFFFFF is returned. Of course, the chances of mysql returning something that large is remote, but I thought I'd bring this up.
Possible fix:
if (0 > n_items)
n_items=0x7FFFFFFF;
// internal capacity limit warning message?
On lines 156:
for( int i = 0; MYSQL_ROW dbrow = mysql_fetch_row( result ); i++ )
Assignment is happening in a conditional (which is fine) but to keep the compiler from issuing a warning at the higher warning levels:
MYSQL_ROW dbrow;
for( int i = 0; 0 != (dbrow = mysql_fetch_row( result )); i++ )
Here's a diff of the changes:
52c52,56
< cfg_value.boolean_value = strtol( value, 0, 2 );
> if ( (1 == tmp) )
> else
67c71
< cfg_value.decimal_value = atof( value );
154a159,163
> if (0 > n_items)
> n_items=0x7FFFFFFF;
156c165,166
< for( int i = 0; MYSQL_ROW dbrow = mysql_fetch_row( result ); i++ )
> MYSQL_ROW dbrow;
