No live stream in IE7 or IE6.
Dirky
Post by Dirky »
I can stream video from ZM in Safari and Firefox fine. In IE it does not
seem to work.
I have cambozloa.jar in the web root of zm, permissions seem ok on it.
When I access the camera stream from IE, I notice in the apache error_log file I see the following:-
[Fri Sep 14 09:09:33 2007] [error] [client 192.168.1.252] File does not exist: /var/www/zm/com
When I access in in Safari I get no error other than a harmless missing favicon.ico message.
When viewing in IE I get a red cross in the top left corner (grey square where the image should be) and when I mouseover the image it tells me to "click to activate and use this control"
- clicking does nothing.
Ahhhhh, whilst typing this I decided to copy cambozola.jar to com and what do you know it works fine.!
I did check my config options to see that they were in fact pointing to cambozola.jar and not com.
Anyway it works, I'll post this just in case it helps somebody etc.
Now I can demonstrate this great system to more people, hopefully get an order and donate some dosh!
D
