I thing, that may be very useful set option record diagnostic images separately for each monitor. When I have about 10 monitors and I would "debug" new one, I have function-less diag images from old 10 monitors...
Thanks,
M.
set record diagnostic images separately for each monitor
As diag is normally used temp i think its better to waste them and have a global option. You dont leave it enabled do you? Apart from the increased load whats the problem having diag on all monitors?
James Wilson
Yes, problem is the load and bandwith for bus and disk. This is the similar reason as http://www.zoneminder.com/forums/viewtopic.php?t=9096.
