I have had a working ZM server for several weeks, but since a reboot it has stopped working.
When I change the 'Run State', I get the following in the logs
If I try and start the ZM service from the commandline, I get :Sep 19 18:06:03 topaz zms[9527]: ERR [Shared memory not initialised by capture daemon]
Sep 19 18:06:07 topaz zmpkg[9534]: INF [Command: start]
Sep 19 18:06:08 topaz zmdc[9549]: INF [Server starting at 07/09/19 18:06:08]
Sep 19 18:06:10 topaz zmdc[9549]: FAT [Can't bind: Address already in use]
Sep 19 18:06:18 topaz zmdc[9547]: FAT [Can't connect: Permission denied]
Sep 19 18:06:18 topaz zmpkg[9534]: ERR [Unable to run "/usr/bin/zmdc.pl startup", output is "Starting server"]
Can anyone suggest what could be wrong?service zoneminder start
Starting zoneminder: Can't connect: Permission denied at /usr/lib/perl5/vendor_perl/5.8.8/ZoneMinder/Debug.pm line 349
ZoneMinder::Debug::Fatal('Can\'t connect: Permission denied') called at /usr/bin/zmdc.pl line 167
Thanks in advance
Phil
