No events visible via zms after upgrade from 1.22.3
hrabe
Post by hrabe »
No events visible via (nph-)zms after upgrade from 1.22.3, when I click "Stills", images are OK. Distro Slackware 11.0.0 and 12.0.0. New events from zm-1.23.0 are OK.
jameswilson
Post by jameswilson »
I think thats cos of the radical upgrade, old events wont be visible. Didnt Phil mention this in the Announcement or am i dreaming?
James Wilson
hrabe
Post by hrabe »
I thing dreaming:
"FEATURE - ZM can now optionally use a deep file storage tree to avoid the 32k limit on files per directory (Paths->ZM_USE_DEEP_STORAGE) This should only be set on initial install, changing it to a different setting will almost certainly lose all your events. There is currently no migration of events backs and forth between formats. "
I have all events, I have all frames, but streaming for this frames does not work.
jameswilson
oh yeah lol
James Wilson
cordel
Post by cordel »
hrabe wrote:I thing dreaming:
Initial Install meaning a fresh install. There is no upgrade path at this time to migrate the events to the new format since this is a beta release candidate and not an official release.
You can upgrade using the old folder format at this time.
hrabe
Post by hrabe »
Yes, I try old format and I see Frames but not stream (ZM_USE_DEEP_STORAGE=0). With new format (ZM_USE_DEEP_STORAGE=1) frames can not be visible too, that is no problem.
jameswilson
so i wasnt dreaming
James Wilson
cordel
Post by cordel »
And I have to ask since you haven't mentioned it. Have you restarted all the services each time you changed and of those settings?
zoneminder
Site Admin
Post by zoneminder »
Just to clarify, provided you don't change to use deep storage a regular upgrade will work just fine and events will be kept.
Can you check whether you installed mootools (See other thread). I forgot to mention it in the release note but it is important. Also check logs obviously for messages from zms.
Phil
turbocsc
Event Streaming problem.
Post by turbocsc »
Hello, I just upgraded to ZM 1.23.1 on Fedora 6. Everthing seems to function fine except for viewing events. I can see still images from events, but cannot receive a stream from an event. I did find the following error with debug logging turned on. Notice that it is getting a monitor ID of zero. I don't see where the monitor ID originates from.
I would expect the monitor ID to be in the query displayed in the log (line 2) below.
Is this correct or does it come from another place?
Thanks.
01/19/08 12:24:13.960468 zms[32025].INF-zm_debug.c/304 [New Debug Level = 9, New Debug Log = /tmp/zm_debug.log.32025]
01/19/08 12:24:13.960625 zms[32025].DB1-zms.cpp/91 [Query: mode=jpeg&event=39&frame=1&scale=100&rate=100&maxfps=15&rand=1200767041]
01/19/08 12:24:13.961525 zms[32025].DB1-zm_monitor.cpp/1964 [Got 0 monitors]
01/19/08 12:24:13.961547 zms[32025].FAT-zm_stream.cpp/37 [Unable to load monitor id 0 for streaming]
01/19/08 12:24:13.961734 zms[32025].ERR-zm_signal.cpp/77 [Got signal (Aborted), crashing]
01/19/08 12:24:13.961778 zms[32025].ERR-zm_signal.cpp/95 [Signal address is 0x202, no eip
01/19/08 12:24:13.962114 zms[32025].ERR-zm_signal.cpp/116 [Backtrace: /lib64/libc.so.6 [0x3a3b430210]]
01/19/08 12:24:13.962152 zms[32025].ERR-zm_signal.cpp/116 [Backtrace: /lib64/libc.so.6(gsignal+0x35) [0x3a3b4301b5]]
01/19/08 12:24:13.962186 zms[32025].ERR-zm_signal.cpp/116 [Backtrace: /lib64/libc.so.6(abort+0x110) [0x3a3b431b20]]
01/19/08 12:24:13.962219 zms[32025].ERR-zm_signal.cpp/116 [Backtrace: /var/www/cgi-bin/nph-zms [0x425fe7]]
01/19/08 12:24:13.962253 zms[32025].ERR-zm_signal.cpp/116 [Backtrace: /var/www/cgi-bin/nph-zms [0x40b57d]]
01/19/08 12:24:13.962285 zms[32025].ERR-zm_signal.cpp/116 [Backtrace: /var/www/cgi-bin/nph-zms [0x403fa3]]
01/19/08 12:24:13.962321 zms[32025].ERR-zm_signal.cpp/116 [Backtrace: /lib64/libc.so.6(__libc_start_main+0xf4) [0x3a3b41da44]]
01/19/08 12:24:13.962354 zms[32025].ERR-zm_signal.cpp/116 [Backtrace: /var/www/cgi-bin/nph-zms(__gxx_personality_v0+0x181) [0x4037b9]]
01/19/08 12:24:13.962386 zms[32025].INF-zm_signal.cpp/117 [Backtrace complete]
turbocsc
Post by turbocsc »
I found the source of my problem. When I installed my first version of zm, I installed it at /var/www/html/zm. When I upgraded to zm 1.23.1 I installed it at /var/ww/html. In my web browser I kept using /var/www/html/zm which used the incorrect set of PHP files. I deleted all the PHP files under my old path and started using the new one and now I can view events normally.
