Page 1 of 1
Progress bar does not work, DVR interface too
Posted: Fri Sep 21, 2007 5:29 pm
by hrabe
Event view progress bar does not work, DVR interface does not work too. Distro Slackware 11.0.0, all browsers.
Posted: Fri Sep 21, 2007 6:59 pm
by monex
hi,
to get the DVR interface working you have to install
mootools. I dont't know which components are needed so select all and move the downloaded file to your zm web directory and rename it to "mootools.v1.11.js". after this the DVR interface should work
hope this helps
Posted: Sat Sep 22, 2007 9:25 am
by hrabe
monex: thank you very much for your great response, now DVR interface is more better, but with some problems.
Posted: Sun Sep 23, 2007 1:12 pm
by zoneminder
Yes, installing mootools is extremely important and I totally forgot to mention it!
Posted: Wed Oct 10, 2007 2:29 pm
by gola10
monex wrote:hi,
hope this helps
Where is the WEB directory?
Posted: Wed Oct 10, 2007 2:34 pm
by cordel
He means your web root directory.
