cpu temperature with sensors
aleppax
Post by aleppax »
I've added the monitoring of the cpu temp using sensors and a simple php function. Here is the code (sensors must be installed and configured; the content of the function is a first attempt tested only on my box):
zm_funcs.php (add this function:)
function getTemperature()
        $te = shell_exec( 'sensors' );
        $tem = explode("temp2:",$te);
	$tempe = explode("C",$tem[1]);
	return( $tempe[0] );
zm_html_view_console.php (line 226 becomes:)
<td class="smallhead" align="right"><?= $zmSlangLoad ?>: <?= getLoad() ?> / <?= $zmSlangDisk ?>: <?= getDiskPercent() ?>% / <?= getTemperature() ?>&deg;C</td>
the function can be easily adapted to monitor also the motherboard temperature.
Lee Sharp
Post by Lee Sharp »
That could be handy. I have had many systems die from a sudden change in environmental heat. It would be nice to know.
qriff
Post by qriff »
Great, other option would be to combine/embed/run Munin graphs with Zoneminder.
http://munin.projects.linpro.no
Live demo: http://munin.ping.uio.no/
robi
Re: cpu temperature with sensors
Post by robi »
aleppax wrote:I've added the monitoring of the cpu temp using sensors and a simple php function. Here is the code (sensors must be installed and configured; the content of the function is a first attempt tested only on my box):
Many thanks, it works great! 8)
v1.25.0 + Ubuntu Linux 12.04 Server
robi
Post by robi »
Just to clarify for the people, before someone says it's not working.
sensors outputs something like this, depending on the motherboard and settings:
it8712-isa-0290 Adapter: ISA adapter VCore 1: +1.52 V (min = +1.42 V, max = +1.57 V) VCore 2: +2.54 V (min = +2.40 V, max = +2.61 V) +3.3V: +3.23 V (min = +3.14 V, max = +3.47 V) +5V: +4.11 V (min = +4.76 V, max = +5.24 V) ALARM +12V: +12.29 V (min = +11.39 V, max = +12.61 V) -12V: -16.19 V (min = -12.63 V, max = -11.41 V) ALARM -5V: -8.17 V (min = -5.26 V, max = -4.77 V) ALARM Stdby: +3.95 V (min = +4.76 V, max = +5.24 V) ALARM VBat: +4.08 V M/B Temp1: +25 C (low = +15 C, high = +40 C) sensor = thermistor M/B Temp2: +26 C (low = +15 C, high = +45 C) sensor = thermistor CPU Temp: +34 C (low = +15 C, high = +65 C) sensor = diode
The line in bold is what we need, so for this example above, the code must be changed like this:
        $tem = explode("CPU Temp:",$te);
So one has to find the words before the reported cpu temperature and replace them in the code above. lm_sensors configuration file offers a lot of nice things also.
linuxsense
Post by linuxsense »
Great idea...thanks for the code. I made a few small changes and have mine set to display both of my cpu cores. Sweet.
For those of you looking to add the temp display with ZM 1.23 look at or around line 269 to insert the temp display code in zm_html_view_console.php...at least as of RC3.
robi
Post by robi »
linuxsense wrote:to add the temp display with ZM 1.23 look at or around line 269 to insert the temp display code in zm_html_view_console.php
Yep, that's right there to be inserted. Works like a charm.
Actually I hate the + sign in front of the temp (it's obvoius that this is a positive temperature, dohh), so to remove
   return(str_replace("+","", $tempe[0]));
 / Cpu:<?= getTemperature() ?>&deg;C
robi
Post by robi »
If you're using 1.24.x, then the mods are the following:
in the file
/var/www/zm/includes/functions.php
add this function:
        $tem = explode("CPU:",$te);
   return(str_replace(" ","", str_replace("+","", $tempe[0])));
(make sure to adjust code according to what your sensors outputs, see above)
in the file
/var/www/zm/skins/classic/views/console.php
search for:
      <h3 id="systemStats"><?= $SLANG['Load'] ?>: <?= getLoad() ?> / <?= $SLANG['Disk'] ?>: <?= getDiskPercent() ?>%</h3>
and replace with:
      <h3 id="systemStats"><?= $SLANG['Load'] ?>: <?= getLoad() ?> / <?= $SLANG['Disk'] ?>: <?= getDiskPercent() ?>% / Cpu: <?= getTemperature() ?>&deg;C</h3>
