I own an analogue camera (FBAS) connected to a Leadtek WinFast VC100 XP PCI-Framegrabber-Card with a BT878-chipset:
ZM gets a picture from the v4l-device (/dev/video0), but from time to time it looks like ZM "looses" the signal (OSD-date is then 1.1.1970) for some seconds. Another symptom is, that I never reach the full fps-rate of 25 fps (PAL). When I configure lower frame-rate, it's also not constantly reached.
The bttv-driver outputs the always following error messages:
Sep 27 13:53:07 cctvserver kernel: bttv0: OCERR @ 3858001c,bits: VSYNC HSYNC OFLOW FBUS OCERR*
Sep 27 13:53:25 cctvserver kernel: bttv0: OCERR @ 3858001c,bits: HSYNC OFLOW OCERR*
Sep 27 13:53:25 cctvserver zma_m1[5390]: INF [camera1: 7000 - Processing at 18.52 fps]
Sep 27 13:53:43 cctvserver kernel: bttv0: OCERR @ 3858001c,bits: VSYNC HSYNC OFLOW OCERR*
Sep 27 13:53:44 cctvserver zmc_dvideo0[5493]: INF [camera1: 4000 - Capturing at 18.52 fps]
Sep 27 13:53:54 cctvserver kernel: bttv0: OCERR @ 3858001c,bits: HSYNC OFLOW FBUS OCERR*
Sep 27 13:54:00 cctvserver kernel: bttv0: OCERR @ 3858001c,bits: HSYNC OFLOW FBUS OCERR*
Sep 27 13:54:19 cctvserver zma_m1[5390]: INF [camera1: 8000 - Processing at 18.52 fps]
Sep 27 13:54:34 cctvserver kernel: bttv0: OCERR @ 3858001c,bits: HSYNC OFLOW FBUS OCERR*
Sep 27 13:54:35 cctvserver kernel: bttv0: OCERR @ 3858001c,bits: HSYNC OFLOW OCERR*
Sep 27 13:54:38 cctvserver zmc_dvideo0[5493]: INF [camera1: 5000 - Capturing at 18.52 fps]
Sep 27 13:54:41 cctvserver kernel: bttv0: OCERR @ 3858001c,bits: HSYNC OFLOW OCERR*
Sep 27 13:54:48 cctvserver kernel: bttv0: OCERR @ 3858001c,bits: HSYNC OFLOW OCERR*
Sep 27 13:54:58 cctvserver kernel: bttv0: OCERR @ 3858001c,bits: HSYNC OFLOW FBUS OCERR*
Sep 27 13:55:02 cctvserver kernel: bttv0: OCERR @ 3858001c,bits: HSYNC OFLOW OCERR*
Sep 27 16:35:06 cctvserver zmc_dvideo0[3673]: INF [Debug Level = 0, Debug Log = <none>]
Sep 27 16:35:06 cctvserver zmdc[2827]: INF ['zmc -d /dev/video0' starting at 07/09/27 06:35:06, pid = 3673]
Sep 27 16:35:06 cctvserver kernel: bttv0: reset, reinitialize
Sep 27 16:35:06 cctvserver kernel: bttv0: PLL: 28636363 => 35468950 . ok
Sep 27 16:35:06 cctvserver zmc_dvideo0[3673]: INF [Starting Capture]
Sep 27 16:35:10 cctvserver kernel: bttv0: timeout: drop=6278 irq=317395/317395, risc=36a2561c, bits: VSYNC HSYNC OFLOW RISCI
Sep 27 16:35:15 cctvserver zmdc[2827]: INF [Starting pending process, zmc -d /dev/video0]
Sep 27 16:35:15 cctvserver zmdc[3674]: INF ['zmc -d /dev/video0' started at 07/09/27 06:35:15]
Sep 27 16:35:15 cctvserver zmdc[2827]: INF ['zmc -d /dev/video0' starting at 07/09/27 06:35:15, pid = 3674]
Sep 27 16:35:15 cctvserver zmc_dvideo0[3674]: INF [Debug Level = 0, Debug Log = <none>]
Sep 27 16:35:15 cctvserver kernel: bttv0: reset, reinitialize
Sep 27 16:35:15 cctvserver kernel: bttv0: PLL: 28636363 => 35468950 . ok
Sep 27 16:35:15 cctvserver zmc_dvideo0[3674]: INF [Starting Capture]
Sep 27 16:35:22 cctvserver zma_m1[2851]: INF [camera1: 232000 - Processing at 13.16 fps]
bttv: driver version 0.9.16 loaded
bttv: using 8 buffers with 2080k (520 pages) each for capture
bttv: Bt8xx card found (0).
bttv0: Bt878 (rev 17) at 0000:00:01.0, irq: 16, latency: 32, mmio: 0xec000000
bttv0: detected: Leadtek WinFast VC 100 [card=114], PCI subsystem ID is 107d:6607
bttv0: using: Winfast VC100 [card=114,autodetected]
bttv0: gpio: en=00000000, out=00000000 in=00ffffff [init]
bttv0: using tuner=4
bttv0: i2c: checking for TDA9887 @ 0x86... not found
bttv0: registered device video0
bttv0: registered device vbi0
IRQ problems: this was the first problem I thought of. So tried to change the slots of the PCI cards in the server in many different ways. The grabber card has now it's own IRQ, but there is nearly no difference. Worst configuration (nothing was displayed) was, when the grabber card had to share its IRQ with a network card.
BTTV parameters: I also tried several parameters of the bttv-module including to specify other cards (card=nnn) or to enlarge the number of capture buffers (gbuffers). Nothing changed.
Changed resolution and fps-rate:
This is the only thing where I can notice clearly, that the number of error messages decreases, when I configure ZM to use a higher resolution (eg 640x480) and decreases if use a lower resolution (320x240, nearly no errors from bttv). The resolution I want (480x360), doesnt work without errors , but when I use 320x240@10fps there is nearly no error message in the kernel log.
Please: can someone give me a hint what I can try else or how I can isolate the problem?
THANKS IN ADVANCE and best regards,
Kurt.
PS: Here is also the output from ZMU:
# zmu -d /dev/video0 -q -v
Video Capabilities
Name: BT878 video (Winfast VC100)
Type: 171
Can capture
Can tune
Overlay onto frame buffer
Can clip
Scalable
Video Channels: 3
Audio Channels: 0
Maximum Width: 924
Maximum Height: 576
Minimum Width: 48
Minimum Height: 32
Window Attributes
X Offset: 0
Y Offset: 0
Width: 320
Height: 240
Picture Attributes
Palette: 4 - 24bit RGB
Colour Depth: 24
Brightness: 32768
Hue: 32768
Colour :32768
Contrast: 32768
Whiteness: 0
Channel 0 Attributes
Channel: 0
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 1 Attributes
Channel: 1
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 2 Attributes
Channel: 2
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
