AVI as input
cyruspy
AVI as input
Post by cyruspy »
Hi, got a Ovislink WL-5420CAM and would like to use it with ZM, the problem is it uses a supper ugly interface that needs ActiveX. It has a feature to record AVI files (with the date as part of the name) on a samba share, but no option to upload jpg files...
Is it possible to use a AVI file that's being updated as input for zoneminder?
Lee Sharp
Post by Lee Sharp »
You have to write something to take the AVI stream, and strip it to jpegs, and spool that to ZM. Generally it is cheaper or easier just to get a camera that works.
cyruspy
Post by cyruspy »
Pretty much assumed it... As a new user of ZoneMinder wasn't sure about the valid input formats... Thanks for replying...
RoundSparrow
Post by RoundSparrow »
Google produces a lot of pages with that model # and references to "motion jpeg". You sure it doesn't also output in jpeg mode?
