1.22.3 error can't login
sergiut2002
Post by sergiut2002 »
I tried to login to webinterface and i couldn`t.
when i ssh and tried to restart zm i got this:
Stopping ZoneMinder: Can't open log file '/var/log/zmpkg.log': Read-only file system at /usr/lib/perl5/site_perl/5.8.8/ZoneMinder/Debug.pm line 279.
rm: cannot remove '/var/lock/susbsys/zm': Read-only file system
Starting ZoneMinder: Can't open log file '/var/log/zmpkg.log': Read-only file system at /usr/lib/perl5/site_perl/5.8.8/ZoneMinder/Debug.pm line 279.
Can't open log file '/var/log/zm/zmdc.log': Read-only file system at /usr/lib/perl5/site_perl/5.8.8/ZoneMinder/Debug.pm line 279.
Can't connect: Connection refused at /usr/lib/perl5/site_perl/5.8.8/ZoneMinder/Debug.pm line 349
ZoneMinder::Debug::Fatal('Can\'t connect: Connection refused) called at /usr/lib/zm/bin/zmdc.pl line 167
tried to reboot remotely and system went dead :(
i don`t understand after working for 1 week almost what happened...
I`m using the live cd 1.22.3 installed on hdd.
________
Vapir no2
PeterHoward
Re: 1.22.3 error can't login
Post by PeterHoward »
sergiut2002 wrote:I tried to login to webinterface and i couldn`t.
It sounds like this is a system problem; nothing to do (directly) with zoneminder. The key is the repeated:
It looks like /var became read-only for some reason. Once you get the system alive again check the state of the various partitions.
Lee Sharp
Post by Lee Sharp »
bring up a cli and type 'mount' and see if the disk is "dirty" and mounted read only.
sergiut2002
re
it seems my ram was with problems. changed the ram memory and now it`s fine. I reinstalled everything and now works
________
Honda Cb350F
