Ubuntu 7.04 (feisty) - missing apache.conf
ziopippo
Post by ziopippo »
I've accidentally delete my /etc/zm/apache.conf with my remote telnet (logged with root). :cry:
I've also delete my DB and reinstall the zm v1.22.3.8 .deb package (whith apache, php, and my mysql) and lose all my events.
Now i cant find the apache.conf. Where can i find it? Or how can i to regenerate or create a new of it? :oops:
Thanks.
________
William Bushnell Stout
Lee Sharp
Post by Lee Sharp »
Using the apt front end of your choice, reinstall apache2 and apqache2.2-common for a clean apache. Then you may have to relink the ZM apache conf file.
ziopippo
Post by ziopippo »
thanks anyway but i've solved unpacking the zm deb files and copy the files apache and zoneminder .conf in to /etc/zm directory. :wink:
But now i've another problem. ZM don't start i can't find the log files (i think that aren't generated); i have only this zmpkg.log whit this messages
10/20/07 12:03:35.604112 zmpkg[27934].INF [Command: start]
10/20/07 12:03:35.606780 zmpkg[27934].ERR [Unable to run "/usr/local/bin/zmdc.pl check", output is ""]
:roll:
Sorry for my BAD english! :oops:
ziopippo
Post by ziopippo »
All ok! Solved also this problem :wink:
I've got chmod 755 at all zm*.* files into /usr/local/bin, and now zm run and i have also all log files 8)
