install_driver(mysql) failed: Can't load
andrew_000
Post by andrew_000 »
bash-2.05b# perl zmconfig.pl
Loading config from DB
Am encountering the following problem with zmconfig.pl
Any help would be most appreciated...thanks!
'/usr/local/lib/perl5/site_perl/5.8.1/i586-linux/auto/DBD/mysql/mysql.so'
for module DBD::mysql:
/usr/local/lib/perl5/site_perl/5.8.1/i586-linux/auto/DBD/mysql/mysql.so:
undefined symbol: net_buffer_length at
/usr/local/lib/perl5/5.8.1/i586-linux/DynaLoader.pm line 229. at (eval 1) line 3 Compilation failed in require at (eval 1) line 3. Perhaps a required shared library or dll isn't installed where expected at zmconfig.pl line 1285
andrew_000
Re: install_driver(mysql) failed: Can't load
sorry...version 0.9.16 on Slackware 9.1
andrew_000
Solved...
zoneminder
Site Admin
Post by zoneminder »
Hi Andrew,
Can you tell us what the problem was, in case someone else has the same error?
Cheers,
Phil
