xawtv and channels on bt878
Hi, i have zm up and running the way i want it, but i need to be able to see real time stream from my cameras on the gui desktop.
i was thinking to use xawtv but here is my problem:
xawtv or kdetv scannes all the channels of my bt878 very fast in a loop and i can not get to either
1. make it scan very slow for i.e 30sec each channel, so it like changes between cameras each interval of time
2. have 4 instances of xawtv and make each one of them show only one channel. so i end with 4 open windows of xawtv
user@linux-102:~> xawtv4 -hwconfig
This is xawtv 4.0-pre, running on Linux/i686 (2.6.18.2-34-default)
device configuration "BT878 video (ProVideo PV143)":
bus = PCI:0000:00:0a.0
video = /dev/video0
vbi = /dev/vbi0
dvb = [unset]
sndrec = [unset, using default]
sndplay = [unset, using default]
mixer = [unset, using default]
control = [unset]
device configuration "xv port: 65 (video4linux)":
bus = [unset]
video = port:65
vbi = [unset]
dvb = [unset]
control = [unset]
any tips on how to solve the problem are welcome
video = /dev/video0
vbi = /dev/vbi0
dvb = [unset]
control = [unset]
bus = [unset]
video = port:65
vbi = [unset]
dvb = [unset]
control = [unset]
A bt878 chip can only view one input of it's four at a time, ZM works by scanning the imputs and taking a capture of each image, on each pass. If you affect the way ZM scans the card, you affect your recorded images as well.
Use shmlib which is a third party app to view cameras in ZM on the same machine.
{EDIT] Link Fix
{EDIT] Link Fix
this is what i get when i am trying to run xlib_shm:
linux-102:/home/user/Documents/xlib_shm-0.6.3 # ./xlib_shm
./xlib_shm: error while loading shared libraries: libmysqlclient.so.12: cannot open shared object file: No such file o
and this is what i have installed:
linux-102:/home/user/Documents/xlib_shm-0.6.3 # locate mysqlclient
/usr/lib/libmysqlclient_r.so.15
/usr/lib/libmysqlclient_r.so.15.0.0
/usr/lib/libmysqlclient.so.15
/usr/lib/libmysqlclient.so.15.0.0
/usr/lib/mysql/libmysqlclient_r.so.15
/usr/lib/mysql/libmysqlclient_r.so.15.0.0
/usr/lib/mysql/libmysqlclient.so.15
/usr/lib/mysql/libmysqlclient.so.15.0.0
any idea what do i have to do in order to be able to run the xlib_shm ?
ok i have recompile xlib_shm on my open suse 10.2 i586 box
and this is what i get:
linux-102:/home/user/Documents/xlib_shm-0.6.3 # make clean
rm -f *.o *.core xlib_shm
gcc -c xlib_shm.c -I/usr/X11R6/include
gcc xlib_shm.o -L/usr/X11R6/lib -lXv -lXext -lX11 -lmysqlclient -Wl,-rpath=/usr/X11R6/lib -o xlib_shm
linux-102:/home/user/Documents/xlib_shm-0.6.3 # ./xlib_shm -m 1
xlib_shm viewer for zm 1.22.3 version 0.6.3
Can't open /usr/local/etc/zm.confSegmentation fault
whats wrong ?
whats wrong ?
ok i kind of resolved the problem
i did not have /usr/local/etc/zm.conf
so i try creating ln -s zm.conf /usr/local/etc/zm.conf
but it did not work for me
so i just cp zm.conf /usr/local/etc/
and it works
but now i see it B/W with lines and the stream is at the same speed as the mozilla montage feature
how to progress from here ?
and it works
linux-102:/home/user/Documents/xlib_shm-0.6.3 # lspci
00:00.0 Host bridge: VIA Technologies, Inc. VT8753 [P4X266 AGP] (rev 01)
00:01.0 PCI bridge: VIA Technologies, Inc. VT8633 [Apollo Pro266 AGP]
00:0a.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
00:0a.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
00:0c.0 Ethernet controller: Intel Corporation 82557/8/9 [Ethernet Pro 100] (rev 08)
00:11.0 ISA bridge: VIA Technologies, Inc. VT8233 PCI to ISA Bridge
00:11.1 IDE interface: VIA Technologies, Inc. VT82C586A/B/VT82C686/A/B/VT823x/A/C PIPC Bus Master IDE (rev 06)
00:11.2 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 1b)
00:11.3 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 1b)
00:11.4 USB Controller: VIA Technologies, Inc. VT82xxxxx UHCI USB 1.1 Controller (rev 1b)
00:11.5 Multimedia audio controller: VIA Technologies, Inc. VT8233/A/8235/8237 AC97 Audio Controller (rev 30)
01:00.0 VGA compatible controller: nVidia Corporation NV5M64 [RIVA TNT2 Model 64/Model 64 Pro] (rev 15)
linux-102:/home/user/Documents/xlib_shm-0.6.3 # free
total used free shared buffers cached
Mem: 516220 494552 21668 0 42224 108736
-/+ buffers/cache: 343592 172628
Swap: 1052216 103128 949088
linux-102:/home/user/Documents/xlib_shm-0.6.3 # uname -a
Linux linux-102 2.6.18.2-34-default #1 SMP Mon Nov 27 11:46:27 UTC 2006 i686 i686 i386 GNU/Linux
linux-102:/home/user/Documents/xlib_shm-0.6.3 # xvinfo
X-Video Extension version 2.2
screen #0
Adaptor #0: "video4linux"
number of ports: 1
port base: 65
operations supported: PutVideo
supported visuals:
depth 24, visualID 0x23
depth 24, visualID 0x24
depth 24, visualID 0x25
depth 24, visualID 0x26
number of attributes: 7
"XV_ENCODING" (range -1000 to 1000)
client settable attribute
client gettable attribute (current value is 0)
"XV_BRIGHTNESS" (range -1000 to 1000)
"XV_CONTRAST" (range -1000 to 1000)
"XV_SATURATION" (range -1000 to 1000)
"XV_HUE" (range -1000 to 1000)
"XV_MUTE" (range 0 to 1)
"XV_FREQ" (range 0 to 16000)
number of encodings: 28
encoding ID #0: "PAL-composite0"
size: 768 x 576
rate: 0.020000
encoding ID #1: "NTSC-composite0"
size: 640 x 480
rate: 0.016683
encoding ID #2: "SECAM-composite0"
size: 768 x 576
rate: 0.020000
encoding ID #3: "PAL-Nc-composite0"
size: 640 x 576
rate: 0.020000
encoding ID #4: "PAL-M-composite0"
size: 640 x 576
rate: 0.020000
encoding ID #5: "PAL-N-composite0"
size: 768 x 576
rate: 0.020000
encoding ID #6: "NTSC-JP-composite0"
size: 640 x 480
rate: 0.016683
encoding ID #7: "PAL-composite1"
size: 768 x 576
rate: 0.020000
encoding ID #8: "NTSC-composite1"
size: 640 x 480
rate: 0.016683
encoding ID #9: "SECAM-composite1"
size: 768 x 576
rate: 0.020000
encoding ID #10: "PAL-Nc-composite1"
size: 640 x 576
rate: 0.020000
encoding ID #11: "PAL-M-composite1"
size: 640 x 576
rate: 0.020000
encoding ID #12: "PAL-N-composite1"
size: 768 x 576
rate: 0.020000
encoding ID #13: "NTSC-JP-composite1"
size: 640 x 480
rate: 0.016683
encoding ID #14: "PAL-composite2"
size: 768 x 576
rate: 0.020000
encoding ID #15: "NTSC-composite2"
size: 640 x 480
rate: 0.016683
encoding ID #16: "SECAM-composite2"
size: 768 x 576
rate: 0.020000
encoding ID #17: "PAL-Nc-composite2"
size: 640 x 576
rate: 0.020000
encoding ID #18: "PAL-M-composite2"
size: 640 x 576
rate: 0.020000
encoding ID #19: "PAL-N-composite2"
size: 768 x 576
rate: 0.020000
encoding ID #20: "NTSC-JP-composite2"
size: 640 x 480
rate: 0.016683
encoding ID #21: "PAL-composite3"
size: 768 x 576
rate: 0.020000
encoding ID #22: "NTSC-composite3"
size: 640 x 480
rate: 0.016683
encoding ID #23: "SECAM-composite3"
size: 768 x 576
rate: 0.020000
encoding ID #24: "PAL-Nc-composite3"
size: 640 x 576
rate: 0.020000
encoding ID #25: "PAL-M-composite3"
size: 640 x 576
rate: 0.020000
encoding ID #26: "PAL-N-composite3"
size: 768 x 576
rate: 0.020000
encoding ID #27: "NTSC-JP-composite3"
size: 640 x 480
rate: 0.016683
Adaptor #1: "NV Video Blitter"
number of ports: 32
port base: 66
operations supported: PutImage
supported visuals:
depth 24, visualID 0x27
depth 24, visualID 0x28
depth 24, visualID 0x29
depth 24, visualID 0x2a
no port attributes defined
maximum XvImage size: 2046 x 2046
Number of image formats: 5
guid: 59555932-0000-0010-8000-00aa00389b71
bits per pixel: 16
number of planes: 1
type: YUV (packed)
guid: 59563132-0000-0010-8000-00aa00389b71
bits per pixel: 12
number of planes: 3
type: YUV (planar)
guid: 55595659-0000-0010-8000-00aa00389b71
bits per pixel: 16
number of planes: 1
type: YUV (packed)
guid: 49343230-0000-0010-8000-00aa00389b71
bits per pixel: 12
number of planes: 3
type: YUV (planar)
guid: 03000000-0000-0010-8000-00aa00389b71
bits per pixel: 32
number of planes: 1
type: RGB (packed)
depth: 24
red, green, blue masks: 0xff0000, 0xff00, 0xff
again my problem now is that i see the stream form the cameras (2) in B/W and with lines across the picture
this is how it looks:
[img]
http://picasaweb.google.com/yavan22/Zon ... 2516048018
[/img]
the card was autodetected by SuSe so i asume it is autodetected i will try to change the setting manually
and check it out, you are correct regarding the path.
just for my knowledge what is the difference ?
one more question do i have to see a line in my xorg.conf file regarding xvideo enabled and rgb32 ?
because i do not see one
this is what i have found within modpobe.conf regarding bttv:
# options bttv pll=1 radio=0 card=0
# options tuner type=0
# options msp3400 once=1 simple=1
# install bttv /sbin/modprobe --ignore-install bttv && { /sbin/modprobe -k tuner; /sbin/modprobe -k msp3400; }
what do i have to change here ?
also this is my dmesg | grep bttv
linux-102:/etc # dmesg | grep bttv
bttv: driver version 0.9.16 loaded
bttv: using 8 buffers with 2080k (520 pages) each for capture
bttv: Bt8xx card found (0).
bttv0: Bt878 (rev 17) at 0000:00:0a.0, irq: 5, latency: 32, mmio: 0xe9101000
bttv0: detected: Provideo PV143A [card=105], PCI subsystem ID is aa00:1430
bttv0: using: ProVideo PV143 [card=105,autodetected]
bttv0: gpio: en=00000000, out=00000000 in=00ffffff [init]
bttv0: using tuner=-1
bttv0: i2c: checking for TDA9875 @ 0xb0... not found
bttv0: i2c: checking for TDA7432 @ 0x8a... not found
bttv0: i2c: checking for TDA9887 @ 0x86... not found
bttv0: registered device video0
bttv0: registered device vbi0
bttv0: PLL: 28636363 => 35468950 .<6>usbcore: registered new driver usbfs
are this settings correct ?
