Page 1 of 1
hardware compression mpeg4 card
Posted: Sat Oct 27, 2007 11:54 am
by trendkill82
Hi, do anybody know a hardware compression 16 port DVR Card, what can record 720x576 / 400 (or min. 200) FPS (PAL) with zoneminder?
thanks!
Posted: Sat Oct 27, 2007 6:57 pm
by jameswilson
zm doenst support hardware compression
Posted: Sun Oct 28, 2007 5:09 pm
by trendkill82
ohh... and if i use brutal CPU? xeon or core2duo? so i need 400fps/16cams in high resolution....
Posted: Sun Oct 28, 2007 8:35 pm
by jameswilson
400 fps might be difficult on std hardware, maybe dual processors (ie not dual core) and seperate pci busses. 200fps at cif is doable, 400 id test first
