please help sql problem
Posted: Mon Oct 29, 2007 10:39 am
Starting ZoneMinder: DBI connect('database=zm;host=localhost','zmuser',...) failed: Access denied for user 'zmuser'@'localhost' (using password: YES) at /usr/share/perl5/ZoneMinder/Config.pm line 89
Can't call method "prepare_cached" on an undefined value at /usr/share/perl5/ZoneMinder/Config.pm line 91.
BEGIN failed--compilation aborted at /usr/share/perl5/ZoneMinder/Config.pm line 100.
Compilation failed in require at /usr/share/perl5/ZoneMinder.pm line 33.
BEGIN failed--compilation aborted at /usr/share/perl5/ZoneMinder.pm line 33.
Compilation failed in require at /usr/bin/zmpkg.pl line 45.
BEGIN failed--compilation aborted at /usr/bin/zmpkg.pl line 45.
failure
invoke-rc.d: initscript zoneminder, action "start" failed.
dpkg: error processing zoneminder (--install):
subprocess post-installation script returned error exit status 255
Errors were encountered while processing:
zoneminder
i really don`t know what to set,. i get this error when i try to run sudo dpkg -i zoneminder_1.22.3-8_i386.deb
I don`t know anything about mysql. As far as i can see it`s a problem with access to zm datagbase. But i don`t know how to give access toit
________
VAPIR NO2
failure
zoneminder
________
VAPIR NO2
