viewing ZM on nintendo wii
ynn
Post by ynn »
i just tried using my son's nintendo wii viewing the ZM, it looked awesome. so we dont need to go to computer anymore to see whose outside the door. we just turn the tv on.cool. it just doesn't get stream if i use format=html, format=xhtml is working fine .did anyone try it before?is wii able to view swf or flv?
thanks.
ktheking
Post by ktheking »
Wii is using operabrowser.
Just install operabrowser on your pc and test.
But the real thing you would need to get things working on the image streaming thing is : flash.
Much on the same way that the cambozola thing handles the problem for IExplore. But unfortunately cambozola is made for java. (not supported by wii).
I've been searching around the net as well for a flash solution ,but didn't came across yet.
However many people are interested due to the axis cams.
So there is in fact a demand from the public ,and given the amount of wii's in the world ,getting flash to work for streaming mjpeg should be a matter of time ....
I have a wii as well ,and indeed it would be nice if ZM could be accessed trough one of these ...
About the swf , flv : http://www.zoneminder.com/forums/viewto ... 4e99053c3c
Cordel wrote :
Yeah I'm afraid your a bit behind Shocked
If you go to the images tab in options:
ZM_MPEG_LIVE_FORMAT swf or flv
ZM_MPEG_REPLAY_FORMAT swf or flv
and your set to go Wink
I think we've been doing it for just over a year Confused
Cheers, and thank you for an alternative though Very Happy
ynn
Post by ynn »
yes, i can view swf and flv buy not streaming one.can you?
linuxsense
Post by linuxsense »
Not wii related, but I have been using my DS to aim cameras. Works pretty good. You just connect to the LAN via WiFi and use the Opera browser for the NDS. Its not perfect, but you can get good enough performance so you can aim the cameras without getting down off the ladder or roof...
cordel
Post by cordel »
ZM can already send a flash stream. Set swf in the config for streaming format. This assumes of coarse you have ffmpeg compiled and installed.
