Hello, i have a tv wonder VE and im not very sharp with linux so bear with me
The card is picked up and installed according to the pci bus scan. When i go to the camera to view it its just a black screen. I have the camera plugged into the composite input and have tried teh device channels 0-4 and they are all black with no static or any movement. What is my next step to troubleshoot this.
Much appreciated.
-Tommy
New to ZM and need help with ati tv wonder VE
Re: New to ZM and need help with ati tv wonder VE
open camera in live view, click settings and adjust all values to around 30000 and see if you get any image. if you do, adjust those values to get best image you can. i have sony handycam hooked up to dont remember what video capture card that way and had exactly the same problem.kilobit wrote:Hello, i have a tv wonder VE and im not very sharp with linux so bear with me
Much appreciated.
-Tommy
if common sense is so uncommon, why is it called common then?
