The Arecont Vision is a great camera. It was easy to set up and get an image in my browser, but I can't get it to work with ZM. I hope somebody can help.
The cameras do output either a static JPEG or MGPEG stream. The Arecont Vision manual gives plenty of url options to configure the video stream to how you want it. Using this URL string, I can get a great picture in my browser:
http://192.168.1.202/mjpeg?res=full&x0= ... r=HTTP/1.1
This produces a 1920x1200 mjpeg image at 1 frame per second.
In the ZM source setup, I have the following configuration
host: 192.168.1.202
port: 80
path: /mjpeg?res=full&x0=0&y0=0&x1=100%&y1=100%&quality=12&doublescan=0&fps=1&ver=HTTP/1.1
It's just not working! I've raised the shared memory in the kernal to about as much RAM as the machine has. Here are outputs from zmdc.log (monitor 2 & 3 are the Arecont cams):
$ tail -f zmdc.log
11/16/2007 16:10:27.441829 zmdc[16910].INF [Starting pending process, zmc -m 2]
11/16/2007 16:10:27.452491 zmdc[16910].INF ['zmc -m 2' starting at 07/11/16 16:10:27, pid = 17335]
11/16/2007 16:10:27.496948 zmdc[16910].ERR ['zmc -m 2' exited abnormally, exit status 7]
11/16/2007 16:10:27.701751 zmdc[16910].WAR [Can't find process with command of 'zma -m 2']
11/16/2007 16:10:32.097507 zmdc[16910].INF [Starting pending process, zmc -m 2]
11/16/2007 16:10:32.102115 zmdc[16910].INF ['zmc -m 2' starting at 07/11/16 16:10:32, pid = 17347]
11/16/2007 16:10:32.247390 zmdc[16910].ERR ['zmc -m 2' exited abnormally, exit status 7]
11/16/2007 16:10:42.087334 zmdc[16910].INF [Starting pending process, zmc -m 2]
11/16/2007 16:10:42.097633 zmdc[16910].INF ['zmc -m 2' starting at 07/11/16 16:10:42, pid = 17369]
11/16/2007 16:10:42.176940 zmdc[16910].ERR ['zmc -m 2' exited abnormally, exit status 7]
11/16/2007 16:11:02.091865 zmdc[16910].INF [Starting pending process, zmc -m 2]
11/16/2007 16:11:02.096452 zmdc[16910].INF ['zmc -m 2' starting at 07/11/16 16:11:02, pid = 17373]
11/16/2007 16:11:02.189128 zmdc[16910].ERR ['zmc -m 2' exited abnormally, exit status 7]
11/16/2007 16:11:42.076739 zmdc[16910].INF [Starting pending process, zmc -m 2]
11/16/2007 16:11:42.080951 zmdc[16910].INF ['zmc -m 2' starting at 07/11/16 16:11:42, pid = 17385]
11/16/2007 16:11:42.189714 zmdc[16910].ERR ['zmc -m 2' exited abnormally, exit status 7]
11/16/2007 16:11:57.072725 zmdc[16910].INF [Starting pending process, zmc -m 3]
11/16/2007 16:11:57.077260 zmdc[16910].INF ['zmc -m 3' starting at 07/11/16 16:11:57, pid = 17386]
11/16/2007 16:11:57.282124 zmdc[16910].ERR ['zmc -m 3' exited abnormally, exit status 7]
$ cat zm_debug.log.17279
11/16/07 16:08:09.097181 zmc_m2[17279].INF-zm_debug.c/304 [New Debug Level = 1, New Debug Log = /var/log/zm/zm_debug.log.17279]
11/16/07 16:08:09.097810 zmc_m2[17279].DB1-zm_monitor.cpp/1899 [Got 1 monitors]
11/16/07 16:08:09.102187 zmc_m2[17279].DB1-zm_monitor.cpp/253 [monitor purpose=1]
11/16/07 16:08:09.102224 zmc_m2[17279].DB1-zm_monitor.cpp/260 [shm.size=9217036]
11/16/07 16:08:09.112662 zmc_m2[17279].DB1-zm_zone.cpp/49 [Initialised zone 0/All - 1 - 640x480 - Rgb:ff0000, CM:3, MnAT:15, MxAT:0, MnAP:50, MxAP:75000, FB:3x3, MnFP:50, MxFP:50000, MnBS:10, MxBS:0, MnB:0, MxB:0]
11/16/07 16:08:09.132709 zmc_m2[17279].DB1-zm_monitor.cpp/329 [Monitor Roof2 has function 2]
11/16/07 16:08:09.132768 zmc_m2[17279].DB1-zm_monitor.cpp/330 [Monitor Roof2 LBF = '%%s - %y/%m/%d %H:%M:%S', LBX = 0, LBY = 0]
11/16/07 16:08:09.132791 zmc_m2[17279].DB1-zm_monitor.cpp/331 [Monitor Roof2 IBC = 10, WUC = 2, pEC = 2, PEC = 2, EAF = 1, FRI = 1000, RBP = 7, FM = 0]
11/16/07 16:08:09.133077 zmc_m2[17279].DB1-zm_zone.cpp/849 [Got 1 zones for monitor Roof2]
11/16/07 16:08:09.133125 zmc_m2[17279].DB1-zm_zone.cpp/49 [Initialised zone 3/All - 1 - 640x480 - Rgb:ff0000, CM:3, MnAT:25, MxAT:0, MnAP:9216, MxAP:230400, FB:3x3, MnFP:9216, MxFP:230400, MnBS:6144, MxBS:0, MnB:1, MxB:0]
11/16/07 16:08:09.152761 zmc_m2[17279].DB1-zm_monitor.cpp/2036 [Loaded monitor 2(Roof2), 1 zones]
11/16/07 16:08:09.152816 zmc_m2[17279].INF-zmc.cpp/183 [Starting Capture]
11/16/07 16:08:09.159435 zmc_m2[17279].ERR-zm_signal.cpp/77 [Got signal (Bus error), crashing]
11/16/07 16:08:09.159653 zmc_m2[17279].ERR-zm_signal.cpp/95 [Signal address is 0x10246, no eip
11/16/07 16:08:09.160145 zmc_m2[17279].ERR-zm_signal.cpp/116 [Backtrace: /lib/libc.so.6 [0x2ac93ca86d40]]
11/16/07 16:08:09.160306 zmc_m2[17279].ERR-zm_signal.cpp/116 [Backtrace: /usr/local/bin/zmc [0x412dcf]]
11/16/07 16:08:09.160432 zmc_m2[17279].ERR-zm_signal.cpp/116 [Backtrace: /usr/local/bin/zmc [0x413bd1]]
11/16/07 16:08:09.160618 zmc_m2[17279].ERR-zm_signal.cpp/116 [Backtrace: /usr/local/bin/zmc [0x4151b3]]
11/16/07 16:08:09.160745 zmc_m2[17279].ERR-zm_signal.cpp/116 [Backtrace: /usr/local/bin/zmc [0x416542]]
11/16/07 16:08:09.160867 zmc_m2[17279].ERR-zm_signal.cpp/116 [Backtrace: /usr/local/bin/zmc [0x40399c]]
11/16/07 16:08:09.160988 zmc_m2[17279].ERR-zm_signal.cpp/116 [Backtrace: /lib/libc.so.6(__libc_start_main+0xf4) [0x2ac93ca738e4]]
11/16/07 16:08:09.161108 zmc_m2[17279].ERR-zm_signal.cpp/116 [Backtrace: /usr/local/bin/zmc(__gxx_personality_v0+0x141) [0x403349]]
11/16/07 16:08:09.161227 zmc_m2[17279].INF-zm_signal.cpp/117 [Backtrace complete]
