Shared Memory Question
seabro
Post by seabro »
I can't grasp this shared memory thing. :(
I currently have 512Mb RAM - and the following.
[root@localhost ~]cat /proc/sys/kernel/shmall
2097152
[root@localhost ~]# cat /proc/sys/kernel/shmmax
33554432
Is it easy for you gurus to tell me what is the max I can increase my shared memory to without killing my Asterisk server (running on same box)
or doesn't it work like that?
jameswilson
Post by jameswilson »
how much do you need, ie number of cams, ring buffer size etc
James Wilson
seabro
Post by seabro »
Hi James,
I currently have one cam, running 320x240 but I have another on order.
I would like to run 640x480 if that was possible...
As for buffers, I don't really know. I am running at 3fps normal and 6fps in alarm on MoDect.
Currently, 'Image Buffer Size (frames)' is set to 40 and both 'Pre Event Image Buffer' and 'Post Event Image Buffer' are set to 10
I have been thinking of upgrading to 1Gb, will that change matters? I notice that prior to installing ZM my swap was always 0K but these days there is a small value showing for swap. (Currently 8K).
Thanks for your help!
jameswilson
have yu followed the guide and the numbers in the faq?
James Wilson
seabro
Post by seabro »
Hi James,
I have had a read but I don't quite understand how shmall and shmax relate to each other, the applicantion(s) and the physical RAM / SWAP space etc, which one I should increase and how high I can increase it based on the physical memory in the system and if / how it will affect other applications running on my system.
And so on.
Any assistance appreciated.
ammaross
Post by ammaross »
I have a document that I use to store personal notes about ZM (such as patches I applied/wrote, configurations, etc), and I think my section on shared memory may help you.
If you will be using a large number of cameras, or large resolutions (such as multiple 640x480s), you will need to add these two lines to the end of /etc/sysctl.conf:
kernel.shmall = 32768
kernel.shmmax = 134217728
Then enter these lines at the command prompt:
echo 32768 >/proc/sys/kernel/shmall
echo 134217728 >/proc/sys/kernel/shmmax
*** These figures are based on a 128MB of RAM system. In a system with 1GB of RAM, shmmax should be at least 524288000 (512MB [500*1024*1024]) and shmall should be 128000 (524288000 / 4096).
The procedure is explained here:
http://www.zoneminder.com/index.php?id= ... faq_faq=10
And here:
http://www.zoneminder.com/forums/viewtopic.php?t=9692
Be sure to restart ZM afterward.
So you can see, shmall is the number of 4K blocks you want, which is why I have the / 4096 in the calc. Hope this helps.
