Page 1 of 1
Login issues
Posted: Fri Dec 28, 2007 5:35 pm
by winblowzxp
I'm having a slight issue logging into my ZM setup. I have my server NATted statically to a static IP from my ISP. I can login without problem internally, but when I try to login from outside, it loops back to the login page. Is there something that I need to open in my firewall or is there another problem somewhere else?
Posted: Sat Dec 29, 2007 12:52 am
by jameswilson
security too high on the 'other' machine, cookies etc
Posted: Sat Dec 29, 2007 6:42 am
by Lee Sharp
I just forward port 80 and it works fine. You don't have virtual hosts set up on the ZM system do you?
Posted: Sat Dec 29, 2007 10:36 am
by winblowzxp
jameswilson wrote:security too high on the 'other' machine, cookies etc
If I tunnel into my network so I get a local IP address it works.
Lee Sharp wrote:I just forward port 80 and it works fine. You don't have virtual hosts set up on the ZM system do you?
I have my box on a DMZ on my network. I'm not running any virtual hosts.
Here's a basic layout of my network: I have a Cisco 2600 connecting to the internet. I NAT running and I have the public address to my linux box statically set in NAT so that everything that goes to that IP address goes to my linux box. Other PHP applications that I have residing on that machine have no problems inside or out. The only issue I'm having is with ZM.
Posted: Sun Dec 30, 2007 1:36 pm
by winblowzxp
I didn't realize this until just recently. I get an IE error:
Line: 7
Char: 1
Error: Access is denied
Code: 0
URL: my server address
Posted: Sun Dec 30, 2007 8:58 pm
by Lee Sharp
Something is not right. Is routing set correctly on the ZM server? I have several ZM servers behind firewalls and have never seen this problem.
