Error compiling Zoneminder
jubstuff
Post by jubstuff »
Hi all! I'm trying to install zoneminder 1.23 from source but i'll keep having error messages :( The "configure" part goes well, but when i "make" here it is what i get:
make  all-recursive
make[1]: Entering directory `/home/justin/Desktop/ZoneMinder-1.23.0'
Making all in src
make[2]: Entering directory `/home/justin/Desktop/ZoneMinder-1.23.0/src'
g++ -DHAVE_CONFIG_H -I. -I..  -I/usr/lib/mysql/include -I/usr/lib/include   -g -O2 -MT zmc.o -MD -MP -MF .deps/zmc.Tpo -c -o zmc.o zmc.cpp
mv -f .deps/zmc.Tpo .deps/zmc.Po
g++ -DHAVE_CONFIG_H -I. -I..  -I/usr/lib/mysql/include -I/usr/lib/include   -g -O2 -MT zm.o -MD -MP -MF .deps/zm.Tpo -c -o zm.o zm.cpp
mv -f .deps/zm.Tpo .deps/zm.Po
g++ -DHAVE_CONFIG_H -I. -I..  -I/usr/lib/mysql/include -I/usr/lib/include   -g -O2 -MT zm_db.o -MD -MP -MF .deps/zm_db.Tpo -c -o zm_db.o zm_db.cpp
mv -f .deps/zm_db.Tpo .deps/zm_db.Po
g++ -DHAVE_CONFIG_H -I. -I..  -I/usr/lib/mysql/include -I/usr/lib/include   -g -O2 -MT zm_config.o -MD -MP -MF .deps/zm_config.Tpo -c -o zm_config.o zm_config.cpp
zm_config.cpp:27: warning: deprecated conversion from string constant to ‘char*’
mv -f .deps/zm_config.Tpo .deps/zm_config.Po
g++ -DHAVE_CONFIG_H -I. -I..  -I/usr/lib/mysql/include -I/usr/lib/include   -g -O2 -MT zm_coord.o -MD -MP -MF .deps/zm_coord.Tpo -c -o zm_coord.o zm_coord.cpp
mv -f .deps/zm_coord.Tpo .deps/zm_coord.Po
g++ -DHAVE_CONFIG_H -I. -I..  -I/usr/lib/mysql/include -I/usr/lib/include   -g -O2 -MT zm_box.o -MD -MP -MF .deps/zm_box.Tpo -c -o zm_box.o zm_box.cpp
mv -f .deps/zm_box.Tpo .deps/zm_box.Po
g++ -DHAVE_CONFIG_H -I. -I..  -I/usr/lib/mysql/include -I/usr/lib/include   -g -O2 -MT zm_poly.o -MD -MP -MF .deps/zm_poly.Tpo -c -o zm_poly.o zm_poly.cpp
mv -f .deps/zm_poly.Tpo .deps/zm_poly.Po
g++ -DHAVE_CONFIG_H -I. -I..  -I/usr/lib/mysql/include -I/usr/lib/include   -g -O2 -MT zm_image.o -MD -MP -MF .deps/zm_image.Tpo -c -o zm_image.o zm_image.cpp
mv -f .deps/zm_image.Tpo .deps/zm_image.Po
g++ -DHAVE_CONFIG_H -I. -I..  -I/usr/lib/mysql/include -I/usr/lib/include   -g -O2 -MT zm_stream.o -MD -MP -MF .deps/zm_stream.Tpo -c -o zm_stream.o zm_stream.cpp
mv -f .deps/zm_stream.Tpo .deps/zm_stream.Po
g++ -DHAVE_CONFIG_H -I. -I..  -I/usr/lib/mysql/include -I/usr/lib/include   -g -O2 -MT zm_event.o -MD -MP -MF .deps/zm_event.Tpo -c -o zm_event.o zm_event.cpp
mv -f .deps/zm_event.Tpo .deps/zm_event.Po
g++ -DHAVE_CONFIG_H -I. -I..  -I/usr/lib/mysql/include -I/usr/lib/include   -g -O2 -MT zm_zone.o -MD -MP -MF .deps/zm_zone.Tpo -c -o zm_zone.o zm_zone.cpp
mv -f .deps/zm_zone.Tpo .deps/zm_zone.Po
g++ -DHAVE_CONFIG_H -I. -I..  -I/usr/lib/mysql/include -I/usr/lib/include   -g -O2 -MT zm_camera.o -MD -MP -MF .deps/zm_camera.Tpo -c -o zm_camera.o zm_camera.cpp
mv -f .deps/zm_camera.Tpo .deps/zm_camera.Po
g++ -DHAVE_CONFIG_H -I. -I..  -I/usr/lib/mysql/include -I/usr/lib/include   -g -O2 -MT zm_local_camera.o -MD -MP -MF .deps/zm_local_camera.Tpo -c -o zm_local_camera.o zm_local_camera.cpp
mv -f .deps/zm_local_camera.Tpo .deps/zm_local_camera.Po
g++ -DHAVE_CONFIG_H -I. -I..  -I/usr/lib/mysql/include -I/usr/lib/include   -g -O2 -MT zm_remote_camera.o -MD -MP -MF .deps/zm_remote_camera.Tpo -c -o zm_remote_camera.o zm_remote_camera.cpp
mv -f .deps/zm_remote_camera.Tpo .deps/zm_remote_camera.Po
g++ -DHAVE_CONFIG_H -I. -I..  -I/usr/lib/mysql/include -I/usr/lib/include   -g -O2 -MT zm_file_camera.o -MD -MP -MF .deps/zm_file_camera.Tpo -c -o zm_file_camera.o zm_file_camera.cpp
mv -f .deps/zm_file_camera.Tpo .deps/zm_file_camera.Po
g++ -DHAVE_CONFIG_H -I. -I..  -I/usr/lib/mysql/include -I/usr/lib/include   -g -O2 -MT zm_monitor.o -MD -MP -MF .deps/zm_monitor.Tpo -c -o zm_monitor.o zm_monitor.cpp
mv -f .deps/zm_monitor.Tpo .deps/zm_monitor.Po
g++ -DHAVE_CONFIG_H -I. -I..  -I/usr/lib/mysql/include -I/usr/lib/include   -g -O2 -MT zm_user.o -MD -MP -MF .deps/zm_user.Tpo -c -o zm_user.o zm_user.cpp
mv -f .deps/zm_user.Tpo .deps/zm_user.Po
g++ -DHAVE_CONFIG_H -I. -I..  -I/usr/lib/mysql/include -I/usr/lib/include   -g -O2 -MT zm_mpeg.o -MD -MP -MF .deps/zm_mpeg.Tpo -c -o zm_mpeg.o zm_mpeg.cpp
zm_mpeg.cpp: In destructor ‘VideoStream::~VideoStream()’:
zm_mpeg.cpp:281: error: cannot convert ‘ByteIOContext’ to ‘ByteIOContext*’ for argument ‘1’ to ‘int url_fclose(ByteIOContext*)’
zm_mpeg.cpp: In member function ‘double VideoStream::EncodeFrame(uint8_t*, int, bool, unsigned int)’:
zm_mpeg.cpp:325: warning: ‘img_convert’ is deprecated (declared at /usr/include/ffmpeg/avcodec.h:2636)
make[2]: *** [zm_mpeg.o] Error 1
make[2]: Leaving directory `/home/justin/Desktop/ZoneMinder-1.23.0/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/justin/Desktop/ZoneMinder-1.23.0'
make: *** [all] Error 2
What could it be??
Thankx to anyone :)
jubstuff
Post by jubstuff »
I've managed to eliminate the warnings installing the latest ffmpeg-svn, but the error
still occurs....any idea????
wildpossum
Post by wildpossum »
I too am having the same problem with just a normal config. See below:
<make>
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/include -I/usr/local/include -g -O2 -MT zm_mpeg.o -MD -MP -MF .deps/zm_mpeg.Tpo -c -o zm_mpeg.o zm_mpeg.cpp
zm_mpeg.cpp:325: warning: ‘img_convert’ is deprecated (declared at /usr/include/ffmpeg/avcodec.h:2410)
make[2]: Leaving directory `/usr/src/ZM/ZM-Sources/ZoneMinder-1.23.0/src'
make[1]: Leaving directory `/usr/src/ZM/ZM-Sources/ZoneMinder-1.23.0'
</make>
Helpful suggestions please.
Grahame
wildpossum
To assist further here is my config arguments.
$ ./configure --with-libarch=lib64 --with-extralibs=-lmp3lame --with-mysql=/usr --with-ffmpeg=/usr/local --with-webdir=/var/www/html --with-cgidir=/var/www/cgi-bin --with-webuser=apache --with-webgroup=apache --enable-crashtrace=yes --enable-debug=yes ZM_DB_HOST=ringtail.wildpossum.com ZM_DB_NAME=zm ZM_DB_USER=zmuser ZM_DB_PASS=xxxxxx
Grahame
wildpossum
OK. The same issue has propted itself up in compiling 1.22.x as well with the latest ffmpeg sources. I simply changed line:280 of zm_mpeg.cpp to be:
To: #if !ZM_FFMPEG_SVN
NB: the '!' interprets as NOT ZM_FFMPEG_SVN all compiling now works OK. Mind you this is a logic rearrangement of the source condition on how to close the output file based on whether the source comes from SVN or not, so I am not sure of the consequences of doing so - just be aware of it, until an official patch is made.
Grahame
jubstuff
Post by jubstuff »
Thank you!! It worked like a charm!! :D
zoneminder
Site Admin
Post by zoneminder »
There was a change in ffmpeg which meant that 1.23.0 had to change to reflect it. Unless they have changed it back again it should be ok in 1.23.0
Phil
decibel83
Post by decibel83 »
zoneminder wrote:There was a change in ffmpeg which meant that 1.23.0 had to change to reflect it. Unless they have changed it back again it should be ok in 1.23.0
No, I have the same problem compiling the 1.23.1 version...
Coudl you help me please?
nsedley
Post by nsedley »
Ditto on CentOS 5 with all the latest updates
johabba
Post by johabba »
same problem here on zm 1.23.1 and debian etch fresh install. i'm using ffmpeg from the debian distro. changing the FFMPEG_SVN check allowed zm to compile.
zoneminder
Site Admin
This is odd as if I get the latest ffmpeg I can compile with no problems. Can you look in your package for the ffmpeg version.h file and post what it's contents are.
Mine is as follows
#define FFMPEG_VERSION "SVN-r11597"
The trouble is there is no indication of when the interfaces change from the ffmpeg lot so I have nothing to go on to say which version of the interface to use.
Phil
Hatchet
Post by Hatchet »
I had these make problems also with the Fedora 8 ffmpeg rpm installed. I had to remove the ffmpeg RPM, then install the SVN ffmpeg. No problems after that.
decibel83
Post by decibel83 »
zoneminder wrote:This is odd as if I get the latest ffmpeg I can compile with no problems. Can you look in your package for the ffmpeg version.h file and post what it's contents are.
Mine is as follows
My version is "SVN-r11827", and ZoneMinder does not compile.
What is the "official" solution of this problem?
Shall I change the "#if !ZM_FFMPEG_SVN" line, or I have to do something else?
zoneminder
Site Admin
I have just downloaded the latest svn of ffmpeg (SVN-r11879) and I can compile without problems. Can you confirm that you have definately installed your latest ffmpeg version and if so grep for url_fclose in avio.h in the ffmpeg dir and wherever you installed it (possibly /usr/local/include/ffmpeg?).
Phil
wildpossum
Whilst I have only ffmpeg rpm loaded rather than the latest SVN version
I get the same issue.
System:
Linux ringtail.wildpossum.com 2.6.23.14-107.fc8 #1 SMP Mon Jan 14 22:07:11 EST 2008 x86_64 x86_64 x86_64 GNU/Linux
[gmkelly@ringtail ~]$ rpm -aq|grep ffmpeg
ffmpeg-libs-0.4.9-0.41.20071011.lvn8
ffmpeg-devel-0.4.9-0.41.20071011.lvn8
ffmpeg-0.4.9-0.41.20071011.lvn8
gstreamer-ffmpeg-0.10.3-1.lvn8
ffmpeg2theora-0.19-1.lvn8
[gmkelly@ringtail ~]$ grep url_fclose /usr/include/ffmpeg/avio.h
int url_fclose(ByteIOContext *s);
I hope this assist you to help us.
I'll do a SVN updated and try again.
Grahame
