Page 1 of 2
zmpkg[7759]: ERR [Unable to find valid 'su' syntax]
Posted: Sun Jan 13, 2008 7:11 am
by samiweb
Hello all,
I previously installed zoneminder and it was working fine.
I made some changes on my debian and now, I can't run it !!
when I click on "stopped" and I choose start I have an error on the log /var/log/syslog
Jan 13 08:08:08 debian zmpkg[7928]: INF [Command: start]
Jan 13 08:08:09 debian zmpkg[7928]: ERR [Unable to find valid 'su' syntax]
can anyone help me ?
I have already installed sudo package
Im' runing the 1.23.0 version
thank you
Sami
Posted: Sun Jan 13, 2008 6:54 pm
by FASSIA
Why a lot of people are asking about this error and nobody is replying them?
I have the same problem, but I suppose that this is a common error, so I'm going to keep reading over the forum. If I found something, I'll post a reply
Regards
Posted: Mon Jan 14, 2008 11:19 pm
by zoneminder
Unfortunately I don't have a Debian system so can't check this problem. For distro specific issues there is usually someone who is an expert who can diagnose the problem and recommend a fix. Ubuntu is Debian based I think and there appear to be no problems with that so it may be worth enquiring oif people who are running on that.
Posted: Tue Jan 15, 2008 5:56 am
by samiweb
hello zoneminder & fassia
ok but what does that mean
in which case we have this error ?
may be if we understand the error we can found the solution ?
thank you
Posted: Tue Jan 15, 2008 10:39 am
by FASSIA
Hi samiweb!
I see this error in the syslog everytime I want to start Zoneminder from the frontend (web page). And of corse, the ZM status still "Stopped".
What kind of changes do you make in your Debian?
I´m using Ubuntu (Debian based) and the only weird thing I made is change the shell to bash, doing something like:
rm /bin/sh
ln -s /bin/sh /bin/bash
I think the problem is related to this because the error is about a command syntax...
But I guessing to much =P I hope someone with experience can help a little with this issue.
Posted: Fri Jan 18, 2008 4:49 am
by samiweb
I just made some upgrade ...
I don't understand
Posted: Fri Jan 18, 2008 4:02 pm
by Lee Sharp
As one of the Debian bigots I will tell you why I did not answer your post.
"I made some changes..."
Am I expected to guess? If you messed up your system, and do not know how, it is much easier to reinstall and start from a known good platform than to try and guess what is screwed up. I say the same things to Ubuntu users who install Envy and complain when a major upgrade breaks the system... So rather than make a post that would be less than professional about your poor linux hygine, I chose to pass and let someone else handle this one. Sometimes you need to step back for a while, or you degenerate into one of the "
Search Noob!" shouting idiots...
But I guess others were also stepping back for a while.
Yep. sudo is broke... You compiled it one way, and then changed the way... You also might check your startup scripts. I would say where, but you did not say how you installed it.
So for real help... What were the changes exactly.
How did you install it?
What version?
Posted: Sat Jan 19, 2008 2:04 am
by FASSIA
Hi Lee Sharp! Thanks for the reply.
I will explain my installation procedures:
First I download the 1.23.1 version.
Then unpack it in my Desktop and build it:
./configure --with-webdir=/var/www/zm --with-cgidir=/var/www/zm/cgi
After that I write the MySQL statements:
mysql mysql < db/zm_create.sql
mysql mysql
grant select,insert,update,delete on zm.* to 'zmuser'@localhost identified by 'zmpass';
quit
mysqladmin reload
Then I do a
make install. Next to that I run
/usr/local/bin/zmpkg.pl start
I do a
chmod 644 to zm.conf, then I load the frontend. Everything is allright up to here. But when I try to start Zoneminder from the web panel, the status remain in "Stopped", and the syslog said the 'su' thing.
That's all!
erm... I found this >>>
http://serverwiki.nerdworks.org/index.p ... nce_Server
Is a tutorial to install ZM in a Slackware distro, but I think it could help. I can't read it right now, 'cos it's to late for me, but tomorrow I will do it
Posted: Sat Jan 19, 2008 2:44 am
by cordel
You didn't define a user or group for ZM in ./configure, so did you set the proper user and group in zm.conf so that zm uses the same user as the web server as described in the Documentation?
Posted: Sat Jan 19, 2008 3:12 am
by FASSIA
Yes, I do this stupid thing:
ZM_WEB_USER=root
ZM_WEB_GROUP=root
But I'm only testing, so it doesn't matter =P
Posted: Sat Jan 19, 2008 7:26 am
by cordel
Yes it matters alot, thats why it's in the instructions to use the web user and group. Manerror
Posted: Sat Jan 19, 2008 8:54 pm
by FASSIA
okey =P thanks Cordel, I'm going to re-read the documentation again and then I will try one more time. Samiweb... what about you? Do you found anything else?
Posted: Sat Jan 19, 2008 10:18 pm
by cordel
You should be fine if you just change the user and group in zm.conf. You will have to make sure to check for errors as some things that zm creates will still be root and you will have to change the permissions for things to fall into place (Like the log files for example will be owned by root, you can just delete those, and maybe the sock and pid files.)
Posted: Mon Jan 21, 2008 3:49 pm
by Lee Sharp
You might want to try the .deb for now. After you get to know the program, you can roll your own build, but the .deb is much easier.
Posted: Sun Feb 03, 2008 6:38 am
by samiweb
hello,
I was waiting for a notification from the forum, and I did think that no one has reply
anyway, fo me the situation is the same, I have upgraded to the version to the
1.23.1
and try to compil it the the line command:
./configure --with-webdir=/var/www/zm --with-cgidir=/usr/lib/cgi-bin --with-webuser=www-data --with-webgroup=www-data
But I still have the same problem !!!
Feb 3 06:50:54 debian zmpkg[5010]: INF [Command: start]
Feb 3 06:50:55 debian zmpkg[5010]: ERR [Unable to find valid 'su' syntax]
I also tried to change the user an group to root (just for testing) into the file /usr/local/etc/zm.conf but the same thing happens
Feb 3 07:40:55 debian zmpkg[5486]: INF [Command: start]
Feb 3 07:40:55 debian zmpkg[5486]: ERR [Unable to find valid 'su' syntax]
how can I resolve that ??
thank you
Sami
