linux noob needs help!!
Posted: Sun Jan 13, 2008 8:18 pm
ok guys, im setting up a zoneminder system for a friend, and i think im gonna need some help
ive ordered 3 topica TP-3000DS cameras from bluecherry as well as a PV-155P 16 port capture card. The guy who im doing this already had 7 X10 analogue cameras that he wants me to use with the system (the X10 company is horrible btw). I also have 2 trendnet IP cams. ordered a Dell pc with ubuntu preinstalled on it. ( Inspiron Desktop 530 N, dual core proc, 2 gigs ram ).
i managed to get zm installed with the help of the walkthrough from http://www.howtoforge.com/video_surveil ... der_ubuntu .
so heres where im at: ive got the zm interface up, the IP cams i have running as well. minor problem with that is that i cant do 640x480. If i set the cam to that res and then set ZM to that res, it simply doesnt work. I have 1 of the analogue cams set up on video0 channel 0 (even though the manual says channel 1, its actually 0). additionally i cannot get the analogue cams working at 640x480. they work fine at 320x240.
i guess i should clarify in case it needs saying. the capture card has 2 pigtails, each with 2 sets of 4 bnc connectors. there are 4 green, numbered vid1 - vid4, then 4 blue numbered vid1-vid4. the second pigtail is the exact same. accoring to the "manual" that came with the card, green vid1 - vid4 is channels 1 - 4, but ive found them to actually be 0 - 3. blue vid 1 - vid 4 are channels 4 - 7, and the second pigtail is the same way. basically all 16 inputs are separate channels...
i have 3 other cams on the desk here, and if i plug them into channel 0, each work just fine. when i make a new monitor and set it as say, channel 1, it either gives me a blue screen for teh cam image, or causes the other video0 camera(s) to stop functioning alltogether. Also, under circumstances ive yet to determine, the stream for the cam will flip through all 3 attached video0 cams really fast...
the problems seem to only affect the analogue cams. the ip cam is pretty much solid (minus the little resolution problem, but thats no biggie at the moment). i didnt install anything to get the capture card going, it worked just fine right away (by just fine i mean i could see an image on one of the cams lol)
overall its really weird, and since im such a linux noob i really dunno where to start troubleshooting. I have very little experience with knowing where stuff is in the linux filesystem or how to get relevant data, but i learn fast, so help me please! just be sure to include relevant links or instructions!!
so this is what i know, im using zm v1.22.3 and ubuntu 7.10
thanks a ton in advanced
________
Nevada marijuana dispensaries
________
