I'm running OpenSuse 10.3 64 Bit w/ Logitech QuickCam Orbit AF. I have tested it with KDETV and Skype and both seem to work OK.
But when I run the cammand: "xawtv -device /dev/video0" I get the message:
"This is xawtv-3.95, running on Linux/x86_64 (2.6.22.13-0.3-default) xinerama 0: 1024x768+0+0
X Error of failed request: XF86DGANoDirectVideoMode
Major opcode of failed request: 138 (XFree86-DGA)
Minor opcode of failed request: 1 (XF86DGAGetVideoLL)
Serial number of failed request: 67
Current serial number in output stream: 67"
I haven't tried to hard to get this to work with xawtv because I was just using it to test and once Skype and KDETV both produced Video I moved on. But now I think there's more to this so I'd like work on this a little more.
Any help would be greatly appreciated, thanks in advance.
Dave Koerner
Update:
This QuickCam uses the UVC driver, which is a V4L2 device not a V4L1 so I have to use xawtv4. This solved the problem.
