Page 1 of 1
autologin??
Posted: Sun Jan 20, 2008 9:48 pm
by mmi
can i autologin without ZoneMinder Login screen, direct in ZoneMinder Console after i set firefox to remember password?
Posted: Tue Jan 22, 2008 9:32 pm
by zoneminder
You can use http basic authentication instead of the ZM built in one. Basic auth is when you get the little popup box on some sites. To do this you would need to create a user on ZM, set Options->ZM_AUTH_TYPE to remote and then create the authentication using a .htaccess and password file.
It's a little bit fiddly but if you google for .htaccess and htpasswd you should find a tutorial.
i will try with this
Posted: Wed Jan 23, 2008 5:38 pm
by mmi
Posted: Wed Aug 19, 2009 3:31 pm
by bburton82
hey! is this also possible with auth_ldap? if yes - it would be great if someone can make a example.
regards
br
