Page 1 of 1
Suggestions
Posted: Thu Jan 24, 2008 3:27 am
by pcalleros
New version working great so far...1.23.0 on Mandriva updated from 1.22.
Seeing the following in logs though....
Jan 23 21:09:47 ICS-ZM zma_m1[4215]: INF [Got alarm centre at 126,137, at count 176887]
Jan 23 21:09:47 ICS-ZM zmc_dvideo0[4266]: WAR [Buffer overrun at index 39, slow down capture, speed up analysis or increase ring buffer size]
Jan 23 21:09:48 ICS-ZM zma_m8[4270]: INF [House-Front: 175698 - Gone into alert state]
Jan 23 21:22:28 ICS-ZM zmtrigger[6127]: INF [Opening connection 'Chan2']
Jan 23 21:22:28 ICS-ZM zmtrigger[6127]: INF [Opening connection 'Chan4']
Jan 23 21:22:28 ICS-ZM zmdc[4179]: ERR ['zmtrigger.pl ' exited abnormally, exit status 9]
I have a generic 8 port individual capture chip board with 7 camera currently connected. Running on an "old" 3.0Ghz/512M server.
Any suggestions
Posted: Thu Jan 24, 2008 5:30 am
by wildpossum
As your error message points out.
I would do these two things.
1> slow down capture, [Deferentially I would lower the capture rate to around 10fps.]
2> speed up analysis or
3> increase ring buffer size. [Yep increase the ring buffer size to twice your current setting and see if this solves your issues]. Once your operating OK, then crepe up the capture rate until your satisfied.
Posted: Fri Jan 25, 2008 12:41 am
by pcalleros
Hello Grahame,
Currently my capture rate is set to 2 FPS. I have doubled my ring buffer size. Will check out analysis. Just noticed that while tinkering I had a 1 meg of memory I have 512 of memory. Will increase that 512 to 2 Megs. Thanks for the ack.
Pete
