I was hoping to have varying zones that change with the state change, i.e. "DuringBusiness" state has a zone on each door, however "AfterHours" state has full coverage zone (only care about watching entry/exit during hours, but after hours want to see all movement).
Is this possible at all? I've tried but it doesn't seem to work, unless I'm missing something somewhere.
Thanks!
Bryan
State specific zones
not that i know to but
you could create 2 monitors that have the required zones and enable and disbale as required.
James Wilson
Re: State specific zones
I tried to do almost the same thing today. After examining the source code, it looks like that currently only the function and enable/disable of the monitors can be changed.bryank wrote:Hello,
I was hoping to have varying zones that change with the state change, i.e. "DuringBusiness" state has a zone on each door, however "AfterHours" state ...
James's idea is good, thanks!
Gabor Moczik
