Page 1 of 1
grettings and 1 question
Posted: Mon Feb 04, 2008 10:04 am
by recidivo
HI,
I use zoneminder from 6 mouth and I allready give my little donation to the project because it' s GREAT and I want it to increase.
I have a question.
my camera works only in 320px x 240px but the native risolution tried also in xatv is better and biggest, can you tell me how can I solve the problem?
thanks.
Posted: Mon Feb 04, 2008 10:26 am
by cordel
That is the highest resolution you can get without interlacing.
Most likely if you can not get an image above 320x240 it is due to shared memory setting, but without log information to back that I can't say for sure.
Another cause could be if you have two cams using the same device, the setting for both cams must match.
Check the FAQ in the wiki and troubleshooting in the README.
But again, anything over 320x240 starts interlacing as difined in the NTSC standard.
http://en.wikipedia.org/wiki/Interlace
Posted: Mon Feb 04, 2008 1:57 pm
by recidivo
cordel wrote:That is the highest resolution you can get without interlacing.
thank you for fast reply cordel, i decript your post and will tell you more!
Posted: Mon Feb 04, 2008 3:24 pm
by recidivo
tell me what log do you need
I have a video card with 8 chip and 8 canal work great in zoneminder, with same fix...
