Veo Observer IP NetCam
Confirming that it works like a charm:
Firmware version: 1.8.58.VE
The URL of the picture is
http://xxx.xxx.xxx.xxx/Jpeg/CamImg.jpg
Getting framerates of more than 30fps at 352*288!
How can this be added to the camera profiles?
Supported resolutions: 176*144, 352*288, 320*240, 640*480, 160*120 (and probably 128*96, 704*576, 1280*960, 1280*1024, but didn't test these)
http://www.zoneminder.com/wiki/index.ph ... _IP_NetCam
v1.25.0 + Ubuntu Linux 12.04 Server
For other Veo models, see links below:
http://www.kahunaburger.com/2004/08/12/ ... k-cameras/
It looks like this model is similar with some AvioSys models.
http://codingforums.com/archive/index.php?t-44116.html
http://www.codingforums.com/printthread.php?t=44116
http://www.sunspot.co.uk/Projects/IP_KA ... _notes.htm
http://siteadvisor.se/sites/airtechscub ... s/5348957/
http://www.ertyu.org/steven_nikkel/blog ... webcam.php
And it seems to give an MJPEG stream also, if the URL is
http://xxx.xxx.xxx.xxx/GetData.cgi?Status=1
I was able to flash my Veo Observer IP NetCam with firmware from Orite IP-Cam IC-301. Download from here.robi wrote:I also found that it may be similar with Orite IP-Cam IC-301
It looks newer, as the Veo's firmware version: 1.8.58.VE is Last F/W update: SEP.30.2005, the Orite Firmware version: 02.08.03EN.OR01R is Last F/W update: MAR.15.2006.
The web interface looks totally different but it looks much responsive and it seems to me faster too. Both the JPEG and MJPEG urls work with the new one too.
http://tibet.blogcu.com/5376381/
LOL... it has also a simple auto-refresh html, intended for PDAs:
http://xxx.xxx.xxx.xxx/pda/
Ah! Official site, at the end, LOL:
http://www.oritedriver.com/index.htm
There is at this address "IP-Cam CGI command list - Doc" - that specifies all the modes that allow to control the camera and extract data from it.robi wrote:Ah! Official site, at the end, LOL:
- zoneminder
- Site Admin
- Contact:
Re: Veo Observer IP NetCam
The problem with adding it to the presets is that there looks like no way to control the image size from the url so there isn't any way so specify those values in the preset entries. I will see if I can work out a non-coonfusing way around it. Thanks for your work in this though. I had a Veo Observer a few years ago and it was pants!! I'm glad to see they have improved.robi wrote:Confirming that it works like a charm:
Phil
- zoneminder
- Site Admin
- Contact:
Actually there is something, I found it in the documentation atr the link above. I posted the most common things in the WiKi, but the full documentation has even more.zoneminder wrote:there looks like no way to control the image size from the url so there isn't any way so specify those values
Did you add the MJPEG path too? Watch out, this model requires /GetData.cgi?Status=true, while Gadsports seem to need only GetData.cgi. Without the Status parameter, my ZM wasn't able to decode the stream.zoneminder wrote:Actually, I have some other dimensioness settings in there so I have added it. The path is identical to the Gadsports by the way.
Another good word for this IP camera model, it has standard M12x0.5 thread for the lens. That makes it compatible with various types of camera lens, like these on Ebay:
I changed the default lens that came with it to a wider angle lens with better light factor and results are even better for the location I chose.
