[sck@house ~]$ cat /etc/fedora-release
Fedora Core release 6 (Zod)
[sck@house ~]$ uname -a
Linux house.nogas.org 2.6.22.14-72.fc6 #1 SMP Wed Nov 21 15:12:59 EST 2007 i686 i686 i386 GNU/Linux
But, I could not get the old database to load, so I followed the instructions in the Wiki and ran 'zmupdate.pl –version=1.22.1'
Now, the main page loads, and I think everything is fine, until I try to look at an event and get a blank window.
So, I followed the hints given in this thread and enabled $db_debug in zm_db.php and now in the error_log I see this...
[Wed Feb 06 22:21:45 2008] [error] [client 192.168.8.104] SQL-DEBUG: select E.*,M.Name as MonitorName,M.Width,M.Height,M.DefaultRate,M.DefaultScale from Events as E inner join Monitors as M on E.MonitorId = M.Id where E.Id = '354264', referer: http://192.168.8.4:81/zm/index.php?view=events&page=1&filter[terms][0][attr]=Archived&filter[terms][0][op]==&filter[terms][0][val]=0&filter[terms][1][cnj]=and&filter[terms][1][attr]=DateTime&filter[terms][1][op]=%3E=&filter[terms][1][val]=-1+month&filter[terms][2][cnj]=and&filter[terms][2][attr]=MonitorId&filter[terms][2][op]==&filter[terms][2][val]=8
[Wed Feb 06 22:21:45 2008] [error] [client 192.168.8.104] SQL-DEBUG: select E.* from Events as E inner join Monitors as M on E.MonitorId = M.Id where E.StartTime <= '2008-01-12 10:15:42' order by E.StartTime desc, referer: http://192.168.8.4:81/zm/index.php?view=events&page=1&filter[terms][0][attr]=Archived&filter[terms][0][op]==&filter[terms][0][val]=0&filter[terms][1][cnj]=and&filter[terms][1][attr]=DateTime&filter[terms][1][op]=%3E=&filter[terms][1][val]=-1+month&filter[terms][2][cnj]=and&filter[terms][2][attr]=MonitorId&filter[terms][2][op]==&filter[terms][2][val]=8
[Wed Feb 06 22:21:53 2008] [error] [client 192.168.8.104] PHP Fatal error: Allowed memory size of 16777216 bytes exhausted (tried to allocate 40 bytes) in /home/zm/zm_db.php on line 99, referer: http://192.168.8.4:81/zm/index.php?view=events&page=1&filter[terms][0][attr]=Archived&filter[terms][0][op]==&filter[terms][0][val]=0&filter[terms][1][cnj]=and&filter[terms][1][attr]=DateTime&filter[terms][1][op]=%3E=&filter[terms][1][val]=-1+month&filter[terms][2][cnj]=and&filter[terms][2][attr]=MonitorId&filter[terms][2][op]==&filter[terms][2][val]=8
Allowed memory size of 16777216 bytes exhausted (tried to allocate 10 bytes)
[sck@house zm]$ mysqlcheck -u root -pSECRET_PASSWRD_YO! -e zm
zm.Config OK
zm.ControlPresets OK
zm.Controls OK
zm.Devices OK
zm.Events OK
zm.Filters OK
zm.Frames OK
zm.Groups OK
zm.MonitorPresets OK
zm.Monitors OK
zm.States OK
zm.Stats OK
zm.TriggersX10 OK
zm.Users OK
zm.ZonePresets OK
zm.Zones OK
[sck@house zm]$
javascript: eventWindow( '/zm/index.php?view=event&eid=354264&filter[terms][0][attr]=Archived&filter[terms][0][op]==&filter[terms][0][val]=0&filter[terms][1][cnj]=and&filter[terms][1][attr]=DateTime&filter[terms][1][op]=>=&filter[terms][1][val]=-1+month&filter[terms][2][cnj]=and&filter[terms][2][attr]=MonitorId&filter[terms][2][op]==&filter[terms][2][val]=8&sort_field=DateTime&sort_asc=1&page=1', 'zmEvent', 336, 348 );
For instance, if I manually send the SQL-DEBUG commands to mysql (password changed BTW
[sck@house zm]$ echo "select E.*,M.Name as MonitorName,M.Width,M.Height,M.DefaultRate,M.DefaultScale from Events as E inner join Monitors as M on E.MonitorId = M.Id where E.Id = '354264'" | mysql -u zmuser -pzm_passwd -D zm | wc -l
2
[sck@house zm]$ echo "select E.* from Events as E inner join Monitors as M on E.MonitorId = M.Id where E.StartTime <= '2008-01-12 10:15:42' order by E.StartTime desc" | mysql -u zmuser -pzm_passwd -D zm | wc -l
106224
106224
Scott
