Zoneminder Console always "STOPPED"
beable
Post by beable »
Hi all,
I have installed Zoneminder 1.22.3 on a Trixbox 2.4.20 distro (Centos 5 based).
The installation is ended ok without errors, but when I open Zoneminder Console and I go to "Stopped" link to activate Zm, nothing change; Is is always stopped.
Is there anyone can help me to solve the problem ??
thanks in advance
beable
/var/log/message
Post by beable »
Feb 11 09:48:17 trixbox1 zmc_dvideo[3355]: INF [tele1: 5000 - Capturing at 9.80 fps]
Feb 11 09:49:59 trixbox1 zmc_dvideo[3355]: INF [tele1: 6000 - Capturing at 9.80 fps]
Feb 11 09:51:41 trixbox1 zmc_dvideo[3355]: INF [tele1: 7000 - Capturing at 9.80 fps]
Feb 11 09:53:23 trixbox1 zmc_dvideo[3355]: INF [tele1: 8000 - Capturing at 9.80 fps]
Feb 11 09:55:04 trixbox1 zmc_dvideo[3355]: INF [tele1: 9000 - Capturing at 9.90 fps]
Feb 11 09:56:46 trixbox1 zmc_dvideo[3355]: INF [tele1: 10000 - Capturing at 9.80 fps]
Feb 11 09:58:28 trixbox1 zmc_dvideo[3355]: INF [tele1: 11000 - Capturing at 9.80 fps]
cordel
Post by cordel »
Turn off (disable) selinux.
beable
Selinux is disabled
Post by beable »
Selinux is disable:
/etc/sysconfig/selinux
# This file controls the state of SELinux on the system.
# SELINUX= can take one of these three values:
# enforcing - SELinux security policy is enforced.
# permissive - SELinux prints warnings instead of enforcing.
# disabled - SELinux is fully disabled.
SELINUX=disabled
# SELINUXTYPE= type of policy in use. Possible values are:
# targeted - Only targeted network daemons are protected.
# strict - Full SELinux protection.
SELINUXTYPE=targeted
zoneminder
Site Admin
Post by zoneminder »
Have you read the sticky at the top of this forum and looked at your logs or gone through the troubleshooting prodedure in the documentation?
Phil
cordel
Post by cordel »
Trixbox changes alot of settings in the distro so many things are not set to defaults, unless you find a howto install zm on trixbox, none of the existing howto's will work.
michael smith
Post by michael smith »
Try to compile without pentium 4 options in the ./configure command. It does strange things as I found out.
Cheers
Michael Smith
antoleon
same problem
Post by antoleon »
hello, I have the same problem on a debian server.
Have you found a solution? thanks!
robolo
Post by robolo »
I have the same problem with Centos 5. I had a working install with ZM 1.23.3 but this problem cropped up after upgrqading. Anyone know the cause and/or solution. SELinux is disabled.
robolo
Post by robolo »
I solved this problem and posted the answer here:
http://www.zoneminder.com/forums/viewtopic.php?t=16476
