Error installation 1.23.1
Posted: Mon Feb 18, 2008 12:31 pm
I need assistance with the setup of zoneminder, I'm in the final stage of the installation,
seems that I'm missing a table in the DB of MYSQL, but I don't know what is the structure of that table.
I'm receiiving the following error.
[root@pentagon tmp]# /etc/init.d/zoneminder start
DBD::mysql::st execute failed: Table 'zm.Config' doesn't exist at /usr/lib/perl5/vendor_perl/5.8.8/ZoneMinder/Config.pm line 92.
Can't execute: Table 'zm.Config' doesn't exist at /usr/lib/perl5/vendor_perl/5.8.8/ZoneMinder/Config.pm line 100
BEGIN failed--compilation aborted at /usr/lib/perl5/vendor_perl/5.8.8/ZoneMinder/Config.pm line 100.
Compilation failed in require at /usr/lib/perl5/vendor_perl/5.8.8/ZoneMinder.pm line 33.
BEGIN failed--compilation aborted at /usr/lib/perl5/vendor_perl/5.8.8/ZoneMinder.pm line 33.
Compilation failed in require at /usr/bin/zmupdate.pl line 48.
BEGIN failed--compilation aborted at /usr/bin/zmupdate.pl line 48.
thank you for the assistance.
