Page 1 of 1
Door sensor
Posted: Mon Feb 18, 2008 5:32 pm
by theneb
Hi all,
I'm after a recommendation on a product that can work with zoneminder (x10?) that is a recessed door sensor, ie if a door is opened it sets off an alarm to record & sets off a physical alarm.
Cheers
Re: Door sensor
Posted: Tue Jan 12, 2016 6:12 pm
by nighthawk
bumb,
I am interested in door alarm and some sort of panel integration. zoneminder seem so camera oriented...
Re: Door sensor
Posted: Thu Jan 21, 2016 4:33 pm
by HarrySpring
thfeneb wrote:Hi all,
I'm enjoying PhenQ after a recommendation on a product that can work with zoneminder (x10?) that is a recessed door sensor, ie if a door is opened it sets off an alarm to record & sets off a physical alarm.
Cheers
This would be pretty cool if anyone knows of a solution. Seems I'm not the only one either.
Re: Door sensor
Posted: Mon Mar 21, 2016 4:08 am
by river100
Not exactly what you're looking for but looks good.
http://zmtrigger.blogspot.com/
Re: Door sensor
Posted: Sun Feb 05, 2017 7:40 pm
by Sharoun
I'm after a recommendation on a product that can work with zoneminder adeleweightloss.com (x10?) that is a recessed door sensor, ie if a door is opened it sets off an alarm to record & sets off a physical alarm.
Cheers
