Hi there.
I have been using ZoneMinder for some time now and I really want to get the ffmpeg part working.
After reading all the forum posts here is what i have done so far:
Installed ffmpeg from source:
svn checkout svn://svn.mplayerhq.hu/ffmpeg/trunk ffmpeg
cd ffmpeg
./configure --enable-gpl --enable-swscaler --prefix=/usr/local --enable-shared
make
make install
that works and I end up with the binaries under /usr/local/bin and the libraries under /usr/local/lib
Then I go into my ZM source folder:
cd /usr/local/src/ZoneMinder-1.23.1
./configure --with-webdir=/var/www --with-cgidir=/usr/lib/cgi-bin --with-webuser=www-data --with-webgroup=www-data --with-ffmpeg=/usr/local/lib
And I get all OK. But when I run make install or make && make install I get the following errors:
Making install in src
make[1]: Entering directory `/usr/local/src/ZoneMinder-1.23.1/src'
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/include -I/usr/local/lib/include -g -O2 -MT zmc.o -MD -MP -MF .deps/zmc.Tpo -c -o zmc.o zmc.cpp
In file included from zm_stream.h:27,
from zm_event.h:36,
from zm_zone.h:27,
from zm_monitor.h:29,
from zmc.cpp:27:
zm_mpeg.h:29:29: error: ffmpeg/avformat.h: No such file or directory
zm_mpeg.h:63: error: use of enum ‘PixelFormat’ without previous declaration
zm_mpeg.h:64: error: ISO C++ forbids declaration of ‘AVOutputFormat’ with no type
zm_mpeg.h:64: error: expected ‘;’ before ‘*’ token
zm_mpeg.h:65: error: ISO C++ forbids declaration of ‘AVFormatContext’ with no type
zm_mpeg.h:65: error: expected ‘;’ before ‘*’ token
zm_mpeg.h:66: error: ISO C++ forbids declaration of ‘AVStream’ with no type
zm_mpeg.h:66: error: expected ‘;’ before ‘*’ token
zm_mpeg.h:67: error: ISO C++ forbids declaration of ‘AVFrame’ with no type
zm_mpeg.h:67: error: expected ‘;’ before ‘*’ token
zm_mpeg.h:68: error: ISO C++ forbids declaration of ‘AVFrame’ with no type
zm_mpeg.h:68: error: expected ‘;’ before ‘*’ token
zm_mpeg.h:69: error: ISO C++ forbids declaration of ‘uint8_t’ with no type
zm_mpeg.h:69: error: expected ‘;’ before ‘*’ token
zm_mpeg.h:85: error: ‘uint8_t’ has not been declared
make[1]: *** [zmc.o] Error 1
make[1]: Leaving directory `/usr/local/src/ZoneMinder-1.23.1/src'
make: *** [install-recursive] Error 1
I don't know how to take care of the header problem. From what I have read I need to run make installlib in the ffmpeg source directory, but that doesn't work.
I get
make: *** No rule to make target `installlib'. Stop.
Any ideas?
Thanks.
l
compile with ffmpeg option error: ffmpeg/avformat.h: No such
- zoneminder
- Site Admin
- Contact:
I think you probably want rather than however you may will find you don't need it use --with-ffmpeg at all. You should see configure look for avformat.h or other ffmpeg headers etc so check whether it has found them or not if you are not sure.
Phil
Re: compile with ffmpeg option error: ffmpeg/avformat.h: No
Go see if there is a ffmpeg directory... I found that the newest version had an issue when it went to look for two header files from ffmpeg. See if the files are in another directory under /usr/local/include other then ffmepg. Mine were split up for each lib/app.Ternitzer wrote:Hi there.
l
Then just change edit the zm file that is looking for it.
I can not get into my machine remotely right now or I would tell you exactly what I did.
The solution
The fact is a secondary aspect of Reality.
