compile with ffmpeg option error: ffmpeg/avformat.h: No such
Posted: Wed Feb 27, 2008 3:45 pm
Hi there.
I have been using ZoneMinder for some time now and I really want to get the ffmpeg part working.
After reading all the forum posts here is what i have done so far:
Installed ffmpeg from source:
svn checkout svn://svn.mplayerhq.hu/ffmpeg/trunk ffmpeg
cd ffmpeg
./configure --enable-gpl --enable-swscaler --prefix=/usr/local --enable-shared
make
make install
that works and I end up with the binaries under /usr/local/bin and the libraries under /usr/local/lib
Then I go into my ZM source folder:
cd /usr/local/src/ZoneMinder-1.23.1
./configure --with-webdir=/var/www --with-cgidir=/usr/lib/cgi-bin --with-webuser=www-data --with-webgroup=www-data --with-ffmpeg=/usr/local/lib
And I get all OK. But when I run make install or make && make install I get the following errors:
Making install in src
make[1]: Entering directory `/usr/local/src/ZoneMinder-1.23.1/src'
g++ -DHAVE_CONFIG_H -I. -I.. -I/usr/include -I/usr/local/lib/include -g -O2 -MT zmc.o -MD -MP -MF .deps/zmc.Tpo -c -o zmc.o zmc.cpp
In file included from zm_stream.h:27,
from zm_event.h:36,
from zm_zone.h:27,
from zm_monitor.h:29,
from zmc.cpp:27:
zm_mpeg.h:29:29: error: ffmpeg/avformat.h: No such file or directory
zm_mpeg.h:63: error: use of enum ‘PixelFormat’ without previous declaration
zm_mpeg.h:64: error: ISO C++ forbids declaration of ‘AVOutputFormat’ with no type
zm_mpeg.h:64: error: expected ‘;’ before ‘*’ token
zm_mpeg.h:65: error: ISO C++ forbids declaration of ‘AVFormatContext’ with no type
zm_mpeg.h:65: error: expected ‘;’ before ‘*’ token
zm_mpeg.h:66: error: ISO C++ forbids declaration of ‘AVStream’ with no type
zm_mpeg.h:66: error: expected ‘;’ before ‘*’ token
zm_mpeg.h:67: error: ISO C++ forbids declaration of ‘AVFrame’ with no type
zm_mpeg.h:67: error: expected ‘;’ before ‘*’ token
zm_mpeg.h:68: error: ISO C++ forbids declaration of ‘AVFrame’ with no type
zm_mpeg.h:68: error: expected ‘;’ before ‘*’ token
zm_mpeg.h:69: error: ISO C++ forbids declaration of ‘uint8_t’ with no type
zm_mpeg.h:69: error: expected ‘;’ before ‘*’ token
zm_mpeg.h:85: error: ‘uint8_t’ has not been declared
make[1]: *** [zmc.o] Error 1
make[1]: Leaving directory `/usr/local/src/ZoneMinder-1.23.1/src'
make: *** [install-recursive] Error 1
I don't know how to take care of the header problem. From what I have read I need to run make installlib in the ffmpeg source directory, but that doesn't work.
I get
make: *** No rule to make target `installlib'. Stop.
Any ideas?
Thanks.
l
cd ffmpeg
make
make install
from zm_event.h:36,
from zm_zone.h:27,
from zmc.cpp:27:
I get
Any ideas?
Thanks.
l
