I've got an axis ip-cam that I can set the maximum fps - say 10 fps.
Now monitoring the cam or recording it is perfectly fine.
But as soon as I want to monitor or record at a lower frame rate
- say at 2 fps I get a problem of skipped frames.
Given frames
0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19
I'd expect to see/record frames 0, then 5, then 10, then 15 ecc...
Instead I get 0 1 2 3 then there is a skip to 20 21 22 23 then
40 41 42 43 etc... So I see a bumpy motion instead of a linear
motion.
This happens with 1.22.3 AND 1.23.1.
I've tried to play around with various settings, such as misc->frame skip
and various buffer options without results.
What am I doing wrong?
Cheers
Paolo
problems monitor/record lower fps
If your using mjpeg feeds you MUST not throttle at the server end only the cam end. If you want to use the server to throttle then you MUST use jpeg
James Wilson
OK Now works great eveything!!!
YES now it's working.
Thanks a lot everybody for the quicly reply!
You don't think that it is unlogicall?
Let me know your impression, please, Paolo.
