/dev/video ? how to select video device
Raigedas
Post by Raigedas »
i had very hard time compiling and installing zm on debian. now it looks that zm processes start.
but what about video device? how to select the right one? i have inserted working DVR (pico) card into PCI slot. and "lspci" shows it.
in my system there are these device files:
/dev/video
/dev/video0
/dev/video1
which one is real? is there any simple way to check? something like:
cat /dev/video
i cannot run any X application to check the device, because i do not have X installed on my server.
and what about kernel? i guess that there is no video support compiled in my kernel. do i need it?
Kushnirenko
Re: /dev/video ? how to select video device
Post by Kushnirenko »
cat /dev/video
If you do cat /dev/video0 | hexdump -C you should see a countinuoulsy running output.
You may want to check v4l project. Almost certainly you need CONFIG_VIDEO_BT848=m in your config.
[/b]
