help need for plustek
rsadanan
Post by rsadanan »
i have camera plustek
i tried with the fillowing code to view in internet explorer
<object id="Player" height="480" width="640" border="1"
classid="CLSID:745395C8-D0E1-4227-8586-624CA9A10A8D">
<param name="AutoStart" value="1">
<param name="UIMode" value="none">
<param name="MediaType" value="jpeg">
<param name="NetworkTimeout" value="5000">
<param name="MediaUsername" value="admin">
<param name="MediaPassword" value="password">
<param name="MediaURL" value="http://192.168.1.24:8084/cgi/mjpg/video.cgi">
</object>
can we add this camera in zoneminder
i tried with 320*240 and also 640*480 but i cannot see any image or video
i configured like
root:password@192.168.1.24
port :8084
path /cgi/mjpg/video.cgi
by the above code in ie i can see the video
any help will be appreciated
thanks in adv
byee....
robi
Post by robi »
Do you see anything, if you type this in FireFox?
http://admin:password@192.168.1.24:8084/cgi/mjpg/video.cgi
v1.25.0 + Ubuntu Linux 12.04 Server
rsadanan
Post by rsadanan »
by the above adress and path
i get acess refused
http://192.168.1.24:8084/cgi-bin/Stream ... ookie00000
i get streaming video by this adress
if configure this with zoneminder
i cannot get nothing
0 fps and blank
any idea
rsadanan
Post by rsadanan »
by the above code
http://admin:password@192.168.1.24:8084 ... /video.cgi
i get video in ie as well as in mozilla
but i cannot access in zm
my conf
port 8084
/cgi/mjpg/video.cgi
320*240
i have configured on axis and plustek
axis works and plustek do nothing
in the console window it is in orange
any help please
a
event
Post by event »
did you manage to aquire the stream? otherwise someone suggested
"at least you can pull jpeg snapshots off of the camera
http://82.233.39.160:90/snapshot.jpg"
is this possible with zoneminder right now?
that way cams could be watched over from windows pcs and data stored on linux using zoneminder
After buying an IP1000 from Newegg last November, I finally got around to trying this camera out.
I tried the various remote host path's suggested in this thread, and the following thread...
http://www.zoneminder.com/forums/viewto ... ht=plustek
All in all, I was unable to get this camera to output a usable image without using IE or the junk Windows software the camera came with... not even "/snapshot.jpg" worked for me.
Anyway, just thought I would second the motion that one should avoid using this camera.
