this the error with the bttv card.
with the ip camera i not the problem.
tail -f /var/log/messages
Mar 5 09:28:15 server39 zmwatch[5402]: INF [Restarting capture daemon for web, shared memory not valid]
Mar 5 09:28:15 server39 zmdc[5924]: INF ['zmc -d /dev/video0' started at 08/03/05 09:28:15]
Mar 5 09:28:15 server39 zmdc[5366]: INF ['zmc -d /dev/video0' starting at 08/03/05 09:28:15, pid = 5924]
Mar 5 09:28:15 server39 zmc_dvideo0[5924]: INF [Debug Level = 0, Debug Log = <none>]
Mar 5 09:28:15 server39 zmwatch[5402]: INF ['zmc -d /dev/video0' starting at 08/03/05 09:28:15, pid = 5924]
root@server39:~# free
total used free shared buffers cached
Mem: 1027356 391340 636016 0 8396 208632
-/+ buffers/cache: 174312 853044
Swap: 1975984 0 1975984
root@server39:~# dmesg
[ 0.000000] Linux version 2.6.20-15-generic (root@palmer) (gcc version 4.1.2 (Ubuntu 4.1.2-0ubuntu4)) #2 SMP Sun Apr 15 07:36:31 UTC 2007 (Ubuntu 2.6.20-15.27-generic)
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] sanitize start
[ 0.000000] sanitize end
[ 0.000000] copy_e820_map() start: 0000000000000000 size: 000000000009fc00 end: 000000000009fc00 type: 1
[ 0.000000] copy_e820_map() type is E820_RAM
[ 0.000000] copy_e820_map() start: 000000000009fc00 size: 0000000000000400 end: 00000000000a0000 type: 2
[ 0.000000] copy_e820_map() start: 00000000000e4000 size: 000000000001c000 end: 0000000000100000 type: 2
[ 0.000000] copy_e820_map() start: 0000000000100000 size: 000000003f6b0000 end: 000000003f7b0000 type: 1
[ 0.000000] copy_e820_map() start: 000000003f7b0000 size: 0000000000010000 end: 000000003f7c0000 type: 3
[ 0.000000] copy_e820_map() start: 000000003f7c0000 size: 0000000000030000 end: 000000003f7f0000 type: 4
[ 0.000000] copy_e820_map() start: 000000003f7f0000 size: 0000000000010000 end: 000000003f800000 type: 2
[ 0.000000] copy_e820_map() start: 00000000fed00000 size: 0000000000000400 end: 00000000fed00400 type: 2
[ 0.000000] copy_e820_map() start: 00000000fee00000 size: 0000000000001000 end: 00000000fee01000 type: 2
[ 0.000000] copy_e820_map() start: 00000000ff380000 size: 0000000000c80000 end: 0000000100000000 type: 2
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
[ 0.000000] BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000e4000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000003f7b0000 (usable)
[ 0.000000] BIOS-e820: 000000003f7b0000 - 000000003f7c0000 (ACPI data)
[ 0.000000] BIOS-e820: 000000003f7c0000 - 000000003f7f0000 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000003f7f0000 - 000000003f800000 (reserved)
[ 0.000000] BIOS-e820: 00000000fed00000 - 00000000fed00400 (reserved)
[ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
[ 0.000000] BIOS-e820: 00000000ff380000 - 0000000100000000 (reserved)
[ 0.000000] 119MB HIGHMEM available.
[ 0.000000] 896MB LOWMEM available.
[ 0.000000] found SMP MP-table at 000ff780
[ 0.000000] Entering add_active_range(0, 0, 260016) 0 entries of 256 used
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0 -> 4096
[ 0.000000] Normal 4096 -> 229376
[ 0.000000] HighMem 229376 -> 260016
[ 0.000000] early_node_map[1] active PFN ranges
[ 0.000000] 0: 0 -> 260016
[ 0.000000] On node 0 totalpages: 260016
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 4064 pages, LIFO batch:0
[ 0.000000] Normal zone: 1760 pages used for memmap
[ 0.000000] Normal zone: 223520 pages, LIFO batch:31
[ 0.000000] HighMem zone: 239 pages used for memmap
[ 0.000000] HighMem zone: 30401 pages, LIFO batch:7
[ 0.000000] DMI present.
[ 0.000000] ACPI: RSDP (v000 ACPIAM ) @ 0x000f9350
[ 0.000000] ACPI: RSDT (v001 A_M_I OEMRSDT 0x06000728 MSFT 0x00000097) @ 0x3f7b0000
[ 0.000000] ACPI: FADT (v002 A M I OEMFACP 0x12000601 MSFT 0x00000097) @ 0x3f7b0200
[ 0.000000] ACPI: MADT (v001 A_M_I OEMAPIC 0x06000728 MSFT 0x00000097) @ 0x3f7b0390
[ 0.000000] ACPI: MCFG (v001 A_M_I OEMMCFG 0x06000728 MSFT 0x00000097) @ 0x3f7b0400
[ 0.000000] ACPI: OEMB (v001 A_M_I AMI_OEM 0x06000728 MSFT 0x00000097) @ 0x3f7c0040
[ 0.000000] ACPI: DSDT (v001 ASR18 ASR18116 0x00000116 INTL 0x02002026) @ 0x00000000
[ 0.000000] ACPI: PM-Timer IO Port: 0x808
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[ 0.000000] Processor #0 6:15 APIC version 20
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] enabled)
[ 0.000000] Processor #1 6:15 APIC version 20
[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x82] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x83] disabled)
[ 0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] Allocating PCI resources starting at 40000000 (gap: 3f800000:bf500000)
[ 0.000000] Detected 1795.147 MHz processor.
[ 11.707940] Built 1 zonelists. Total pages: 257985
[ 11.707944] Kernel command line: root=UUID=792aaedf-d79f-4ffe-a592-cf1a588cc15e ro quiet splash locale=it_IT
[ 11.708091] mapped APIC to ffffd000 (fee00000)
[ 11.708093] mapped IOAPIC to ffffc000 (fec00000)
[ 11.708095] Enabling fast FPU save and restore... done.
[ 11.708097] Enabling unmasked SIMD FPU exception support... done.
[ 11.708106] Initializing CPU#0
[ 11.708156] PID hash table entries: 4096 (order: 12, 16384 bytes)
[ 11.709304] Console: colour VGA+ 80x25
[ 11.709535] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 11.709796] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 11.732237] Memory: 1019632k/1040064k available (1992k kernel code, 19664k reserved, 893k data, 328k init, 122560k highmem)
[ 11.732246] virtual kernel memory layout:
[ 11.732247] fixmap : 0xfff4e000 - 0xfffff000 ( 708 kB)
[ 11.732248] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 11.732250] vmalloc : 0xf8800000 - 0xff7fe000 ( 111 MB)
[ 11.732251] lowmem : 0xc0000000 - 0xf8000000 ( 896 MB)
[ 11.732252] .init : 0xc03d7000 - 0xc0429000 ( 328 kB)
[ 11.732253] .data : 0xc02f2264 - 0xc03d16d4 ( 893 kB)
[ 11.732254] .text : 0xc0100000 - 0xc02f2264 (1992 kB)
[ 11.732257] Checking if this processor honours the WP bit even in supervisor mode... Ok.
[ 11.812084] Calibrating delay using timer specific routine.. 3593.06 BogoMIPS (lpj=7186122)
[ 11.812118] Security Framework v1.0.0 initialized
[ 11.812122] SELinux: Disabled at boot.
[ 11.812137] Mount-cache hash table entries: 512
[ 11.812248] CPU: After generic identify, caps: bfebfbff 20000000 00000000 00000000 0000e39d 00000000 00000001
[ 11.812255] monitor/mwait feature present.
[ 11.812257] using mwait in idle threads.
[ 11.812261] CPU: L1 I cache: 32K, L1 D cache: 32K
[ 11.812264] CPU: L2 cache: 2048K
[ 11.812266] CPU: Physical Processor ID: 0
[ 11.812267] CPU: Processor Core ID: 0
[ 11.812269] CPU: After all inits, caps: bfebfbff 20000000 00000000 00003940 0000e39d 00000000 00000001
[ 11.812277] Compat vDSO mapped to ffffe000.
[ 11.812280] Remapping vsyscall page to ffffe000
[ 11.812290] Checking 'hlt' instruction... OK.
[ 11.828154] SMP alternatives: switching to UP code
[ 11.828450] Early unpacking initramfs... done
[ 12.133779] ACPI: Core revision 20060707
[ 12.134038] ACPI: Looking for DSDT in initramfs... file /DSDT.aml not found, using machine DSDT.
[ 12.147199] CPU0: Intel(R) Core(TM)2 CPU 4300 @ 1.80GHz stepping 02
[ 12.147219] SMP alternatives: switching to SMP code
[ 12.147321] Booting processor 1/1 eip 3000
[ 12.157728] Initializing CPU#1
[ 12.235761] Calibrating delay using timer specific routine.. 3590.34 BogoMIPS (lpj=7180690)
[ 12.235768] CPU: After generic identify, caps: bfebfbff 20000000 00000000 00000000 0000e39d 00000000 00000001
[ 12.235772] monitor/mwait feature present.
[ 12.235776] CPU: L1 I cache: 32K, L1 D cache: 32K
[ 12.235778] CPU: L2 cache: 2048K
[ 12.235780] CPU: Physical Processor ID: 0
[ 12.235781] CPU: Processor Core ID: 1
[ 12.235783] CPU: After all inits, caps: bfebfbff 20000000 00000000 00003940 0000e39d 00000000 00000001
[ 12.236192] CPU1: Intel(R) Core(TM)2 CPU 4300 @ 1.80GHz stepping 02
[ 12.236210] Total of 2 processors activated (7183.40 BogoMIPS).
[ 12.236356] ENABLING IO-APIC IRQs
[ 12.236529] ..TIMER: vector=0x31 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 12.383655] checking TSC synchronization across 2 CPUs: passed.
[ 0.004001] Brought up 2 CPUs
[ 0.101590] migration_cost=59
[ 0.101847] Booting paravirtualized kernel on bare hardware
[ 0.101913] Time: 8:20:58 Date: 02/05/108
[ 0.101940] NET: Registered protocol family 16
[ 0.102016] EISA bus registered
[ 0.102020] ACPI: bus type pci registered
[ 0.102157] PCI: PCI BIOS revision 3.00 entry at 0xf0031, last bus=3
[ 0.102159] PCI: Using configuration type 1
[ 0.102160] Setting up standard PCI resources
[ 0.113372] ACPI: Interpreter enabled
[ 0.113374] ACPI: Using IOAPIC for interrupt routing
[ 0.113791] ACPI: PCI Root Bridge [PCI0] (0000:00)
[ 0.113798] PCI: Probing PCI hardware (bus 00)
[ 0.114059] Boot video device is 0000:00:02.0
[ 0.114486] PCI quirk: region 0800-087f claimed by ICH6 ACPI/GPIO/TCO
[ 0.114489] PCI quirk: region 0480-04bf claimed by ICH6 GPIO
[ 0.115045] PCI: Transparent bridge - 0000:00:1e.0
[ 0.115088] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.117595] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P1._PRT]
[ 0.122699] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P4._PRT]
[ 0.122960] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P5._PRT]
[ 0.124815] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 10 *11 12 14 15)
[ 0.125043] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 *10 11 12 14 15)
[ 0.125270] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 *5 6 7 10 11 12 14 15)
[ 0.125496] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 *5 6 7 10 11 12 14 15)
[ 0.125724] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
[ 0.125951] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
[ 0.126177] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
[ 0.126406] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 10 11 12 14 *15)
[ 0.126497] Linux Plug and Play Support v0.97 (c) Adam Belay
[ 0.126508] pnp: PnP ACPI init
[ 0.131597] pnp: PnP ACPI: found 19 devices
[ 0.131600] PnPBIOS: Disabled by ACPI PNP
[ 0.131641] PCI: Using ACPI for IRQ routing
[ 0.131643] PCI: If a device doesn't work, try "pci=routeirq". If it helps, post a report
[ 0.138579] NET: Registered protocol family 8
[ 0.138581] NET: Registered protocol family 20
[ 0.139472] pnp: 00:10: ioport range 0x290-0x29f has been reserved
[ 0.139726] PCI: Ignore bogus resource 6 [0:0] of 0000:00:02.0
[ 0.139729] PCI: Bridge: 0000:00:1c.0
[ 0.139730] IO window: disabled.
[ 0.139734] MEM window: disabled.
[ 0.139738] PREFETCH window: fde00000-fdefffff
[ 0.139743] PCI: Bridge: 0000:00:1c.1
[ 0.139745] IO window: e000-efff
[ 0.139750] MEM window: feb00000-febfffff
[ 0.139753] PREFETCH window: disabled.
[ 0.139758] PCI: Bridge: 0000:00:1e.0
[ 0.139759] IO window: disabled.
[ 0.139763] MEM window: disabled.
[ 0.139766] PREFETCH window: fdf00000-fdffffff
[ 0.139787] ACPI: PCI Interrupt 0000:00:1c.0[A] -> GSI 16 (level, low) -> IRQ 16
[ 0.139793] PCI: Setting latency timer of device 0000:00:1c.0 to 64
[ 0.139810] ACPI: PCI Interrupt 0000:00:1c.1[B] -> GSI 17 (level, low) -> IRQ 17
[ 0.139815] PCI: Setting latency timer of device 0000:00:1c.1 to 64
[ 0.139825] PCI: Setting latency timer of device 0000:00:1e.0 to 64
[ 0.139848] NET: Registered protocol family 2
[ 0.175906] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.175996] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.176464] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.176732] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.176735] TCP reno registered
[ 0.187971] checking if image is initramfs... it is
[ 0.790403] Freeing initrd memory: 7012k freed
[ 0.791048] audit: initializing netlink socket (disabled)
[ 0.791066] audit(1204705258.536:1): initialized
[ 0.791159] highmem bounce pool size: 64 pages
[ 0.791240] VFS: Disk quotas dquot_6.5.1
[ 0.791259] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.791310] io scheduler noop registered
[ 0.791312] io scheduler anticipatory registered
[ 0.791314] io scheduler deadline registered
[ 0.791324] io scheduler cfq registered (default)
[ 0.791547] PCI: Setting latency timer of device 0000:00:1c.0 to 64
[ 0.791587] assign_interrupt_mode Found MSI capability
[ 0.791590] Allocate Port Service[0000:00:1c.0:pcie00]
[ 0.791622] Allocate Port Service[0000:00:1c.0:pcie02]
[ 0.791720] PCI: Setting latency timer of device 0000:00:1c.1 to 64
[ 0.791759] assign_interrupt_mode Found MSI capability
[ 0.791761] Allocate Port Service[0000:00:1c.1:pcie00]
[ 0.791792] Allocate Port Service[0000:00:1c.1:pcie02]
[ 0.791941] isapnp: Scanning for PnP cards...
[ 1.145505] isapnp: No Plug & Play device found
[ 1.165445] Real Time Clock Driver v1.12ac
[ 1.165506] Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
[ 1.165622] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.165741] serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 1.166330] 00:0f: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.166474] mice: PS/2 mouse device common for all mice
[ 1.166993] RAMDISK driver initialized: 16 RAM disks of 65536K size 1024 blocksize
[ 1.167132] input: Macintosh mouse button emulation as /class/input/input0
[ 1.167181] Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
[ 1.167184] ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
[ 1.167490] PNP: PS/2 Controller [PNP0303:PS2K,PNP0f03:PS2M] at 0x60,0x64 irq 1,12
[ 1.170181] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.170185] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 1.170272] EISA: Probing bus 0 at eisa.0
[ 1.170300] EISA: Detected 0 cards.
[ 1.199157] input: AT Translated Set 2 keyboard as /class/input/input1
[ 1.200363] TCP cubic registered
[ 1.200371] NET: Registered protocol family 1
[ 1.200394] Starting balanced_irq
[ 1.200400] Using IPI No-Shortcut mode
[ 1.200497] ACPI: (supports S0 S1 S3 S4 S5)
[ 1.200538] Magic number: 0:473:320
[ 1.200609] hash matches device tty45
[ 1.200778] Freeing unused kernel memory: 328k freed
[ 1.203080] Time: tsc clocksource has been installed.
[ 2.388146] Capability LSM initialized
[ 2.421532] ACPI Exception (acpi_processor-0677): AE_NOT_FOUND, Processor Device is not present [20060707]
[ 2.421541] ACPI Exception (acpi_processor-0677): AE_NOT_FOUND, Processor Device is not present [20060707]
[ 2.786003] usbcore: registered new interface driver usbfs
[ 2.786028] usbcore: registered new interface driver hub
[ 2.786051] usbcore: registered new device driver usb
[ 2.786883] ACPI: PCI Interrupt 0000:00:1d.7[A] -> GSI 23 (level, low) -> IRQ 18
[ 2.786895] PCI: Setting latency timer of device 0000:00:1d.7 to 64
[ 2.786899] ehci_hcd 0000:00:1d.7: EHCI Host Controller
[ 2.787010] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 1
[ 2.787037] ehci_hcd 0000:00:1d.7: debug port 1
[ 2.787042] PCI: cache line size of 32 is not supported by device 0000:00:1d.7
[ 2.787050] ehci_hcd 0000:00:1d.7: irq 18, io mem 0xfea37c00
[ 2.790933] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
[ 2.791026] usb usb1: configuration #1 chosen from 1 choice
[ 2.791051] hub 1-0:1.0: USB hub found
[ 2.791057] hub 1-0:1.0: 8 ports detected
[ 2.805180] USB Universal Host Controller Interface driver v3.0
[ 2.854781] Floppy drive(s): fd0 is 1.44M
[ 2.873557] FDC 0 is a post-1991 82077
[ 2.894056] ACPI: PCI Interrupt 0000:00:1d.0[A] -> GSI 23 (level, low) -> IRQ 18
[ 2.894067] PCI: Setting latency timer of device 0000:00:1d.0 to 64
[ 2.894071] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 2.894091] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 2.894115] uhci_hcd 0000:00:1d.0: irq 18, io base 0x0000d400
[ 2.894199] usb usb2: configuration #1 chosen from 1 choice
[ 2.894220] hub 2-0:1.0: USB hub found
[ 2.894225] hub 2-0:1.0: 2 ports detected
[ 2.997896] ACPI: PCI Interrupt 0000:00:1d.1[B] -> GSI 19 (level, low) -> IRQ 19
[ 2.997907] PCI: Setting latency timer of device 0000:00:1d.1 to 64
[ 2.997911] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 2.997931] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
[ 2.997958] uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000d480
[ 2.998038] usb usb3: configuration #1 chosen from 1 choice
[ 2.998061] hub 3-0:1.0: USB hub found
[ 2.998066] hub 3-0:1.0: 2 ports detected
[ 3.101808] ACPI: PCI Interrupt 0000:00:1d.2[C] -> GSI 18 (level, low) -> IRQ 20
[ 3.101816] PCI: Setting latency timer of device 0000:00:1d.2 to 64
[ 3.101819] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 3.101838] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
[ 3.101862] uhci_hcd 0000:00:1d.2: irq 20, io base 0x0000d800
[ 3.101938] usb usb4: configuration #1 chosen from 1 choice
[ 3.101959] hub 4-0:1.0: USB hub found
[ 3.101965] hub 4-0:1.0: 2 ports detected
[ 3.205726] ACPI: PCI Interrupt 0000:00:1d.3[D] -> GSI 16 (level, low) -> IRQ 16
[ 3.205734] PCI: Setting latency timer of device 0000:00:1d.3 to 64
[ 3.205737] uhci_hcd 0000:00:1d.3: UHCI Host Controller
[ 3.205756] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 5
[ 3.205780] uhci_hcd 0000:00:1d.3: irq 16, io base 0x0000d880
[ 3.205855] usb usb5: configuration #1 chosen from 1 choice
[ 3.205876] hub 5-0:1.0: USB hub found
[ 3.205881] hub 5-0:1.0: 2 ports detected
[ 3.309673] r8169 Gigabit Ethernet driver 2.2LK loaded
[ 3.309696] ACPI: PCI Interrupt 0000:01:00.0[A] -> GSI 17 (level, low) -> IRQ 17
[ 3.309721] PCI: Setting latency timer of device 0000:01:00.0 to 64
[ 3.310351] eth0: RTL8101e at 0xf8824000, 00:19:66:38:80:da, IRQ 17
[ 3.322012] SCSI subsystem initialized
[ 3.340991] libata version 2.20 loaded.
[ 3.342292] ata_piix 0000:00:1f.1: version 2.10ac1
[ 3.342310] ACPI: PCI Interrupt 0000:00:1f.1[A] -> GSI 18 (level, low) -> IRQ 20
[ 3.342330] PCI: Setting latency timer of device 0000:00:1f.1 to 64
[ 3.342425] ata1: PATA max UDMA/133 cmd 0x000101f0 ctl 0x000103f6 bmdma 0x0001ffa0 irq 14
[ 3.342458] ata2: PATA max UDMA/133 cmd 0x00010170 ctl 0x00010376 bmdma 0x0001ffa8 irq 15
[ 3.342475] scsi0 : ata_piix
[ 3.547717] ata1.00: ata_hpa_resize 1: sectors = 156301488, hpa_sectors = 156301488
[ 3.547721] ata1.00: ATA-7: MAXTOR STM3802110A, 3.AAK, max UDMA/100
[ 3.547723] ata1.00: 156301488 sectors, multi 16: LBA48
[ 3.605875] ata1.00: ata_hpa_resize 1: sectors = 156301488, hpa_sectors = 156301488
[ 3.605877] ata1.00: configured for UDMA/100
[ 3.605885] scsi1 : ata_piix
[ 3.605935] ata2: port disabled. ignoring.
[ 3.606050] scsi 0:0:0:0: Direct-Access ATA MAXTOR STM380211 3.AA PQ: 0 ANSI: 5
[ 3.606206] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ]
[ 3.606226] ACPI: PCI Interrupt 0000:00:1f.2[B] -> GSI 19 (level, low) -> IRQ 19
[ 3.606242] PCI: Setting latency timer of device 0000:00:1f.2 to 64
[ 3.606266] ata3: SATA max UDMA/133 cmd 0x0001d080 ctl 0x0001d002 bmdma 0x0001c800 irq 19
[ 3.606285] ata4: SATA max UDMA/133 cmd 0x0001cc00 ctl 0x0001c882 bmdma 0x0001c808 irq 19
[ 3.606293] scsi2 : ata_piix
[ 3.771909] ATA: abnormal status 0x7F on port 0x0001d087
[ 3.771920] scsi3 : ata_piix
[ 3.935789] ATA: abnormal status 0x7F on port 0x0001cc07
[ 3.943627] SCSI device sda: 156301488 512-byte hdwr sectors (80026 MB)
[ 3.943639] sda: Write Protect is off
[ 3.943641] sda: Mode Sense: 00 3a 00 00
[ 3.943654] SCSI device sda: write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 3.943701] SCSI device sda: 156301488 512-byte hdwr sectors (80026 MB)
[ 3.943709] sda: Write Protect is off
[ 3.943711] sda: Mode Sense: 00 3a 00 00
[ 3.943725] SCSI device sda: write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 3.943728] sda: sda1 sda2
[ 3.983972] sd 0:0:0:0: Attached scsi disk sda
[ 3.987486] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 4.224525] Attempting manual resume
[ 4.224528] swsusp: Resume From Partition 8:2
[ 4.224530] PM: Checking swsusp image.
[ 4.249618] PM: Resume from disk failed.
[ 4.293728] kjournald starting. Commit interval 5 seconds
[ 4.293737] EXT3-fs: mounted filesystem with ordered data mode.
[ 11.326818] r8169: eth0: link up
[ 11.326824] r8169: eth0: link up
[ 11.537127] NET: Registered protocol family 10
[ 11.537226] lo: Disabled Privacy Extensions
[ 12.107352] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 12.116715] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 12.268389] Linux agpgart interface v0.102 (c) Dave Jones
[ 12.277337] agpgart: Detected an Intel 945G Chipset.
[ 12.277830] agpgart: Detected 7932K stolen memory.
[ 12.291315] agpgart: AGP aperture is 256M @ 0xd0000000
[ 12.295272] intel_rng: FWH not detected
[ 12.350349] parport: PnPBIOS parport detected.
[ 12.350402] parport0: PC-style at 0x378 (0x778), irq 7, dma 3 [PCSPP,TRISTATE,COMPAT,ECP,DMA]
[ 12.370112] iTCO_vendor_support: vendor-support=0
[ 12.371019] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.01 (11-Nov-2006)
[ 12.371084] iTCO_wdt: Found a ICH7 or ICH7R TCO device (Version=2, TCOBASE=0x0860)
[ 12.371113] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 12.482965] input: PC Speaker as /class/input/input2
[ 12.565227] irda_init()
[ 12.565239] NET: Registered protocol family 23
[ 12.645755] Linux video capture interface: v2.00
[ 12.820262] bttv: driver version 0.9.16 loaded
[ 12.820266] bttv: using 16 buffers with 2080k (520 pages) each for capture
[ 12.820313] bttv: Bt8xx card found (0).
[ 12.820336] ACPI: PCI Interrupt 0000:03:02.0[A] -> GSI 23 (level, low) -> IRQ 18
[ 12.820348] bttv0: Bt878 (rev 17) at 0000:03:02.0, irq: 18, latency: 32, mmio: 0xfdffe000
[ 12.820356] bttv0: subsystem: 3f3f:ff3f (UNKNOWN)
[ 12.820358] please mail id, board name and the correct card= insmod option to video4linux-list@redhat.com
[ 12.820361] bttv0: using: Kodicom 4400R (slave) [card=133,insmod option]
[ 12.820385] bttv0: gpio: en=00000000, out=00000000 in=00fffff3 [init]
[ 12.820900] bttv0: using tuner=4
[ 12.820903] bttv0: i2c: checking for TDA9887 @ 0x86... not found
[ 12.840422] i2c_adapter i2c-0: sendbytes: error - bailout.
[ 12.841444] i2c_adapter i2c-0: sendbytes: error - bailout.
[ 12.843428] tuner 0-0042: chip found @ 0x84 (bt878 #0 [sw])
[ 12.843459] tda9887 0-0042: tda988[5/6/7] found @ 0x42 (tuner)
[ 12.844081] i2c_adapter i2c-0: sendbytes: error - bailout.
[ 12.845104] i2c_adapter i2c-0: sendbytes: error - bailout.
[ 12.846636] i2c_adapter i2c-0: sendbytes: error - bailout.
[ 12.846658] tuner 0-0043: chip found @ 0x86 (bt878 #0 [sw])
[ 12.846681] tda9887 0-0043: tda988[5/6/7] found @ 0x43 (tuner)
[ 12.847534] i2c_adapter i2c-0: sendbytes: error - bailout.
[ 12.848789] i2c_adapter i2c-0: sendbytes: error - bailout.
[ 12.850133] i2c_adapter i2c-0: sendbytes: error - bailout.
[ 12.850156] tuner 0-004a: chip found @ 0x94 (bt878 #0 [sw])
[ 12.850176] tda9887 0-004a: tda988[5/6/7] found @ 0x4a (tuner)
[ 12.850794] i2c_adapter i2c-0: sendbytes: error - bailout.
[ 12.851812] i2c_adapter i2c-0: sendbytes: error - bailout.
[ 12.853554] tuner 0-004b: chip found @ 0x96 (bt878 #0 [sw])
[ 12.853574] tda9887 0-004b: tda988[5/6/7] found @ 0x4b (tuner)
[ 12.854728] tuner 0-0060: It is not a TEA5767. Received -121 bytes.
[ 12.854730] tuner 0-0060: chip found @ 0xc0 (bt878 #0 [sw])
[ 12.855206] tuner 0-0061: chip found @ 0xc2 (bt878 #0 [sw])
[ 12.855453] tuner 0-0062: chip found @ 0xc4 (bt878 #0 [sw])
[ 12.855697] tuner 0-0063: chip found @ 0xc6 (bt878 #0 [sw])
[ 12.856176] tuner 0-0064: chip found @ 0xc8 (bt878 #0 [sw])
[ 12.856418] tuner 0-0065: chip found @ 0xca (bt878 #0 [sw])
[ 12.856665] tuner 0-0066: chip found @ 0xcc (bt878 #0 [sw])
[ 12.856912] tuner 0-0067: chip found @ 0xce (bt878 #0 [sw])
[ 12.857157] tuner 0-0068: chip found @ 0xd0 (bt878 #0 [sw])
[ 12.857402] tuner 0-0069: chip found @ 0xd2 (bt878 #0 [sw])
[ 12.857646] tuner 0-006a: chip found @ 0xd4 (bt878 #0 [sw])
[ 12.857889] tuner 0-006b: chip found @ 0xd6 (bt878 #0 [sw])
[ 12.858133] tuner 0-006c: chip found @ 0xd8 (bt878 #0 [sw])
[ 12.858382] tuner 0-006d: chip found @ 0xda (bt878 #0 [sw])
[ 12.858631] tuner 0-006e: chip found @ 0xdc (bt878 #0 [sw])
[ 12.858875] tuner 0-006f: chip found @ 0xde (bt878 #0 [sw])
[ 12.859023] bttv0: registered device video0
[ 12.859054] bttv0: registered device vbi0
[ 12.859079] bttv0: PLL: 28636363 => 35468950 .. ok
[ 12.890575] tuner 0-0060: tuner type not set
[ 12.966959] bt878: AUDIO driver version 0.0.0 loaded
[ 12.966995] bt878: Bt878 AUDIO function found (0).
[ 12.967015] ACPI: PCI Interrupt 0000:03:02.1[A] -> GSI 23 (level, low) -> IRQ 18
[ 12.967021] bt878_probe: card id=[0xff3f3f3f], Unknown card.
[ 12.967022] Exiting..
[ 12.967027] ACPI: PCI interrupt for device 0000:03:02.1 disabled
[ 12.967031] bt878: probe of 0000:03:02.1 failed with error -22
[ 13.033759] ACPI: PCI Interrupt 0000:00:1b.0[A] -> GSI 16 (level, low) -> IRQ 16
[ 13.033777] PCI: Setting latency timer of device 0000:00:1b.0 to 64
[ 13.042337] input: ImPS/2 Generic Wheel Mouse as /class/input/input3
[ 13.238300] hda_codec: Unknown model for ALC883, trying auto-probe from BIOS...
[ 13.465228] fuse init (API version 7.8)
[ 13.478594] lp0: using parport0 (interrupt-driven).
[ 13.503809] Adding 1975984k swap on /dev/disk/by-uuid/446916be-947e-4f39-8278-25242298466c. Priority:-1 extents:1 across:1975984k
[ 13.625795] EXT3 FS on sda1, internal journal
[ 15.171327] NET: Registered protocol family 17
[ 19.110535] input: Power Button (FF) as /class/input/input4
[ 19.110660] ACPI: Power Button (FF) [PWRF]
[ 19.111321] input: Power Button (CM) as /class/input/input5
[ 19.111441] ACPI: Power Button (CM) [PWRB]
[ 19.194253] ibm_acpi: ec object not found
[ 19.285931] Using specific hotkey driver
[ 19.341947] No dock devices found.
[ 19.373642] pcc_acpi: loading...
[ 22.295659] eth0: no IPv6 routers present
[ 23.950670] [drm] Initialized drm 1.1.0 20060810
[ 23.952971] ACPI: PCI Interrupt 0000:00:02.0[A] -> GSI 16 (level, low) -> IRQ 16
[ 23.953269] [drm] Initialized i915 1.6.0 20060119 on minor 0
[ 24.880852] ppdev: user-space parallel port driver
[ 27.342762] apm: BIOS version 1.2 Flags 0x02 (Driver version 1.16ac)
[ 27.342766] apm: disabled - APM is not SMP safe.
[ 33.351633] Bluetooth: Core ver 2.11
[ 33.351697] NET: Registered protocol family 31
[ 33.351699] Bluetooth: HCI device and connection manager initialized
[ 33.351702] Bluetooth: HCI socket layer initialized
[ 33.433979] Bluetooth: L2CAP ver 2.8
[ 33.433983] Bluetooth: L2CAP socket layer initialized
[ 33.552622] Bluetooth: RFCOMM socket layer initialized
[ 33.552634] Bluetooth: RFCOMM TTY layer initialized
[ 33.552636] Bluetooth: RFCOMM ver 1.8
[ 244.641233] tuner 0-0060: tuner type not set
root@server39:~# ipcs -m
------ Shared Memory Segments --------
key shmid owner perms bytes nattch status
0x00000002 65536 root 600 655360 2
0x00000000 98305 gdm 600 393216 2 dest
0x7a6d2002 196610 www-data 700 36865188 2
0x7a6d200f 229379 www-data 700 36865188 0
------ Shared Memory Limits --------
max number of segments = 4096
max seg size (kbytes) = 819200
max total shared memory (pages) = 838860800
min seg size (bytes) = 1
------ Semaphore Limits --------
max number of arrays = 128
max semaphores per array = 250
max semaphores system wide = 32000
max ops per semop call = 32
semaphore max value = 32767
------ Messages: Limits --------
max queues system wide = 16
max size of message (bytes) = 8192
default max size of queue (bytes) = 16384
Video Capabilities
Name: BT878 video (Kodicom 4400R (sla
Type: 171
Can capture
Can tune
Overlay onto frame buffer
Can clip
Scalable
Video Channels: 16
Audio Channels: 0
Maximum Width: 924
Maximum Height: 576
Minimum Width: 48
Minimum Height: 32
Window Attributes
X Offset: 0
Y Offset: 0
Width: 320
Height: 240
Picture Attributes
Palette: 4 - 24bit RGB
Colour Depth: 24
Brightness: 32768
Hue: 32768
Colour :32768
Contrast: 32768
Whiteness: 0
Channel 0 Attributes
Channel: 0
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 1 Attributes
Channel: 1
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 2 Attributes
Channel: 2
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 3 Attributes
Channel: 3
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 4 Attributes
Channel: 4
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 5 Attributes
Channel: 5
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 6 Attributes
Channel: 6
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 7 Attributes
Channel: 7
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 8 Attributes
Channel: 8
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 9 Attributes
Channel: 9
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 10 Attributes
Channel: 10
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 11 Attributes
Channel: 11
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 12 Attributes
Channel: 12
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 13 Attributes
Channel: 13
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 14 Attributes
Channel: 14
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 15 Attributes
Channel: 15
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
